View Poll Results: Which way is better
Lengthen the body 1 3.45%
Shorten the chassis 18 62.07%
What, are you nuts? 9 31.03%
Other (please post) 1 3.45%
Voters: 29. You may not vote on this poll
Old 01-13-2009, 07:56 PM   #1
JJorgensen52
Simple? What's simple?
JJorgensen52's Avatar
Looking for comments on an idea
I've always wanted a 1st gen Blazer, but I want something 100% reliable and well mannered on the road. I've been toying with the idea of doing a late model chassis swap into the old body style, but was at a loss as to how to compensate for the difference in wheelbase. Cut down the chassis, or extend the body?
The image is to scale, so I've added the 16" needed to the wheelbase ahead of the rear wheel. Oddly enough, an '09 Silverado has almost the same overhang on the chassis as the old blazers do.
Original:
Lengthened:
(and yes, the pics came from ebay). Tell me what you think.
CURRENT
'50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build
'63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos
'66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos
'69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!)
'72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh
'99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily)
'99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs)
SOLD
'71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder)
JJorgensen52 is offline   Reply With Quote
Old 01-14-2009, 12:55 AM   #2
OARNGESI
OARNGESI's Avatar
Re: Looking for comments on an idea
Actually looks decent why not cut down the burb BUT I LIKE THE STOCK LENGTH BLAZERS BETTER SO CUT THE FRAME OR SWAP EVERYTHING TO YOUR FRAME
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 01-14-2009, 07:02 AM   #3
vtblazer
vtblazer's Avatar
May as well get a truck and throw a top on the bed, it would look about the same as the 2nd pic in the end.
What's the wheelbase your shooting for?
Where do your skills lie?
Are you a body-man, glass worker, welder?
All the above?
It would be fairly simple to lengthen the body by just adding/grafting a truck bed onto the 'B' pillar & floor area of the blazer tub but the hard top would be the issue there.
Might make it look 'station wagon-ish' IMO going that route.
Shortening the frame would be very doable too but then your changing the ride characteristics of the later model chassis and the ride your looking to achieve.
How about a third option?
Build the truck your hoping for from an existing 1st gen.
vtblazer is offline   Reply With Quote
Old 01-14-2009, 10:04 AM   #4
JJorgensen52
VTBlazer -
The stock wheelbase on the newer chassis is 120", according to information I've seen the stock blazer is 104" (correct me if I'm wrong).
As for skill level... I think I would be more comfortable with chassis work, but I can do sheet metal fabrication and I do my own prep/paint work. The glassing involved with the top doesn't daunt me, either, although It seems it would be easiest to just mate two tops together, vice extending one.
Part of the reason I'd had the idea in the first place, was keeping all the newer mechanical components for driveability/comfort, but also for serviceability. To that end, I thought of lengthening the body just to avoid changing any of the parts on the late model chassis for interchange purposes.
That said, I drive a new gen Silverado now (technically an 07 due to the build date, but it's an 08 model). I've crawled under the truck, checked and double checked everything, and it would be relatively simple to section 16" out from under the cab right ahead of the spring perches (because, essentially, all the extra length is in the cab). Shortening fuel lines, exhaust, drivetrain, etc would all follow suit without too much issue. I do not believe that it would hugely effect the ride quality, since the biggest improvement in the new trucks is the coilover front end. MAJOR improvement over anything I've driven before. That and the chassis stiffness certainly wouldn't hurt.
Given that it will be a while before I actually do this (I have 2 other projects to get rid of first), I've just been toying with ideas back and forth. I do agree that it might look station wagon-ish.
*prepares to don flame suit*
CURRENT
SOLD
Old 01-14-2009, 11:51 AM   #5
bama51
If you wanna drive it topless, I like the shortened frame. If you want it to seal up good (from water and wind noise), I would shorten a suburban to fit your frame. Just my opinion.
bama51 is offline   Reply With Quote
Old 01-14-2009, 02:19 PM   #6
JJorgensen52
Should have mentioned, want a blazer for the topless abilities.
CURRENT
SOLD
Old 01-14-2009, 02:35 PM   #7
Chevyman63
Can't wait to retire!!
Chevyman63's Avatar
I would think shortening the frame would be a lot less work and I really don't like the longer version of the Blazer. Just my $.02.
2009 4x4 Chevy Crew Cab 6.0
1989 4x4 Siverado (270,000 miles)
1972 4x4 Blazer
2007 Chevy Cutaway 1 ton
1970 Corvette (sons project)
RIP
- CLR 10/11/09
Chevyman63 is offline   Reply With Quote
Old 01-14-2009, 03:49 PM   #8
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
I say hack the chassis, but that's just my $.02
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 01-16-2009, 12:01 PM   #9
Yukon Jack
Post Whore
Yukon Jack's Avatar
I don't care for the extended body version - chop that frame if you do it, would surely be way less work.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 01-16-2009, 12:40 PM   #10
Jtrux
I'm a poor spectator
Jtrux's Avatar
I say just swap in a modern drivetrain into a 1st gen, it will take about 1/1000th of the time and money and did I mention time.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 01-16-2009, 03:22 PM   #11
DANTES JIMMY
DANTES JIMMY's Avatar
I have pondered this for some time and i think it is a fantastic idea and really wish you would do it
i work at a chevy dealership
and i researched a little bit
2008 MODEL YEAR
1/2 ton sb silverado or sierra
wb 119"
3/4 ton lb silv or sierra
wb133"
trailblazer 4x4 with a 5.3 v8 or a 6.0(ss)
wb113"
i can look up any of this stuff for you real quickly if you need any other specs on gm products just let me know
ie: Track width,overhang....
The 07 classic wb numbers are the same
i would think shortening the frame would be a cakewalk compared to extending the body
DANTES JIMMY is offline   Reply With Quote
Old 01-16-2009, 03:31 PM   #12
72BlckButy
Tot Roddin'
72BlckButy's Avatar
x2 Cutting down the chassis would be far less involved and cheaper than extending the body.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 01-17-2009, 07:52 AM   #13
Blazer1970
Blazer1970's Avatar
Nice, but the top will still leak in the rain.
Blazer1970 is offline   Reply With Quote
Old 01-18-2009, 10:59 AM   #14
pumpkin
pumpkin's Avatar
My vote would have to be to make the stock frame and suspension work. The newer ifs trucks, to me don't drive much better than my lifted,on 35's 72 Blazer. The ifs suspension also has a lot more maintenance required, and more parts that will and do wear out. In theory it sounds like a cool idea, but as a mechanic of 30 years, the more I work on the newer **** that all the manufacturers are building, the more I want to stay with my old stuff. In my family, the daily drivers are 72 C20 2WD, 72 Blazer 4X4, 81 Grand Prix, and my wife drives a 97 Yukon 4X4. I have tuned the steering and suspension in the older ones, and prefer driving them much more, and the older ones are cheeper to keep the front ends in good shape, and the tires wear and last better.
pumpkin is offline   Reply With Quote
Old 01-19-2009, 03:24 PM   #15
fun in dirt
fun in dirt's Avatar
I'll second that!!!
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
[B]'85 C10 [B] "Corpse"
'01 2500 Suburban ...party wagon & tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
