01-13-2009, 08:04 PM | #1 |
profeshinaly unimployed
whats the best sound dampening mat
im planing on trying to make my daily driver 82 k10 a little more quite so whats the best sound dampening mat i can get but like not too expensive and does sound damping mats even work
"having mud flaps is like asking for a smaller trophy" Last edited by pokethesmot; 01-13-2009 at 08:05 PM. |
01-13-2009, 08:12 PM | #2 |
Crew Cut
Re: what's the best sound dampening mat
i had good luck with fatmat. it was 129.oo for the kit. (100sq ft) free shipping
85 SWB 1/2 TON CREWCAB/5.3 03 CHEV 3500 DURAMAX CREW CAB 85 CHEV SWB/TPI 06 CHEV TAHOE (WIFES) 30 MODEL A HOT ROD 07 HARLEY DAVIDSON BAGGER 09 STREET GLIDE AN D A LOT MORE JUNK |
01-13-2009, 08:19 PM | #3 |
Re: whats the best sound dampining mat
I used elemental designs. It worked great and it's $1 a sq.ft. It made my cab quiet enough I have to get new mufflers so I can hear the truck again...lol Also it was very sticky, Some people said some brands can come off later on. If you don't have a roller to apply this stuff with, get one or it will suck.
EDIT, about a year and a half after the install... I had to pull the door panel off to put a new inner door handle on and all the stuff is still there, right where I left it. Tried to peel up a corner and couldn't get it. Last edited by 78 Chevyrado; 01-31-2010 at 05:01 AM. |
01-13-2009, 08:53 PM | #4 |
also how much mat do you guys think i might need
"having mud flaps is like asking for a smaller trophy" |
01-13-2009, 08:58 PM | #5 |
truck addict
20 sqr foot if you do the floor and firewall... should have enough left for the doors also
01-13-2009, 09:28 PM | #6 |
Low & Fast!
B-quiet is what I used and I love it and the money is right too..
http://www.b-quiet.com/products.html
01-13-2009, 11:40 PM | #7 |
go to homedepot and look in the roofing section, theres a product called quickroof (yellow cover, kinda small) all it is is tar and aluminun but it works great and is the cheapest thing out there, but i think only home depot has it
01-14-2009, 11:00 AM | #8 |
truck addict
yeah i used somethign similar but it was to seal around the outside of window frames before you putthe siding on.. it was really jsut a thick rubber mat with really strong adhesive on it.. i accedently sealed my trunk shut on my maxima with it when i removed the rubber but left the adhesive on a hot day... it was bad but the stuff worked great when i had it on there.. 2 12" explodes and 2 1000 power acustic amps couldnt make the trunk rattle anymore
trucks |
01-14-2009, 03:20 PM | #9 |
Professional Grade
I've heard that the stuff from home depot makes your truck smell like roofing tar once it sits out in the sun for a little while.
I'm personally going with the dynamat sound deadener.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
01-14-2009, 03:42 PM | #10 |
truck addict
i didnt have any unwanted smells from the stuff i used but it only hame in rolls that where 6 inches across and i think 20 ft long.. so it was a bit of a apin to do my whole truck deck, sides and floor with but the sound quality rivalled that of dynamat for 1/8th of the price..
trucks |
01-14-2009, 05:05 PM | #11 |
I was happy with my second skin sound damplifier.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
01-14-2009, 07:05 PM | #12 | |
the pollock
"TAC mat" it's a dense foam liner but dynamat bought them out and the craps expensive now.. i like dynamat but it's not my style..i like the thick foam stuff without an aluminum backing because it dosent reflect distortion or HI end noise... and both (including) the home depot stuff are great and hold up well in heat
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
01-14-2009, 08:56 PM | #13 |
OutOfMyMind & I'llNeverKnowWhy
Heres a good article comparing the different brands
http://www.sounddeadenershowdown.com/
-Justin-Out of my mind and I'll never know why 1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed 1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6 1992 Pontiac Firebird T-Top 5.0L TBI 700R4 My cardomain page I don't like to save, it's more fun to spend!! |
01-14-2009, 11:20 PM | #14 |
Justins76-
That is probably the best, most thorough independent test I have ever seen. Thank You for posting that!!!!!! |
01-15-2009, 12:28 PM | #15 |
Whats everyone's opinion on gluing this stuff down ? My main concern is if water or moisture gets to it, you can't easily pull it out and dry it.
1977 GMC Sierra Grande |
01-15-2009, 11:32 PM | #16 |
Give this a read before buying any http://www.sounddeadenershowdown.com/ Most of it is glued on one side and once its stuck down its hard to remove so i wouldn't worry about water.If you are worried about water a truck bed liner roll on or spray on will give you some sound deading but its water proof tho.
01-16-2009, 01:32 PM | #17 |
Don't Crush em Restore em
I have bought the Fatmat deal like OJOE, but have yet to install it. Waiting on warmer weather to finish painting my interior parts.
TexasJeff 2009 Silver with Linen Interior Cadillac DTS 1990 Red with White Top and Interior Ford Mustang GT convertible 1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually |
01-17-2009, 03:01 PM | #18 |
Re: whats the best sound dampening mat
B-quiet, Hands down.
Mexican |
01-31-2010, 03:06 AM | #19 | |
Did you do the ceiling and back wall of the cab? Was a 100sq ft plenty to do it? Thanks! Oops, I just realized how old this thread is....sorry
CHEVY ONLY Last edited by joe231; 01-31-2010 at 03:07 AM. |
01-31-2010, 09:47 AM | #20 |
on the sound deadening for the doors do you cover the whole inside of the door skin?
78 C-10 5.3 LSX -4L60E |
01-31-2010, 05:30 PM | #21 |
ive used cheap stuff on ebay all the way to dynamat. the dynamat in my opinion stuck to what i was applying it to better. really all your trying to do is add weight to the panel that your applying it to. made my roof on my H2 very solid.
01-31-2010, 07:03 PM | #22 | |
01-31-2010, 10:09 PM | #23 |
Squarebody Aficionado
any pics of you trucks getting sound deadning installed? i HATE the doors on these trucks there is no room for anything im trying to put my handles back in and door locks but it is the worse thing i have ever encountered
02-01-2010, 12:20 AM | #24 |
Hands down the best I've ever used is Second Skin Damplifier Pro.
Great stuff, nice and thick, sticks really good, and its priced well. |
02-01-2010, 12:34 AM | #25 |
how many square feet is required to do the floor, firewall, headliner, and doors (inside skin and outer skin)?
Greg 1974 GMC 1/2 Ton SWB Fleetside L33 5.3/4l65e .................__
............._____l __\__ ..............l_(O)_ l___(O)] |
