Old 05-13-2002, 05:30 PM   #1
jmanz69
Careful, they attack...
jmanz69's Avatar
Post Hard to install a big block?
I had an idea to put in a big block, like a 427 or 454. Is it hard to get one in? I have a 69 1/2 ton, SWB, stepside with a th-350. I know I would need another trans, but I am more worried about getting the engine in there. Also what about a 4-spd. Could I even get the clutch linkage around the engine. I know some of you guys have big blocks, so I was wondering if you could give some tips. Thanks
jmanz69
69 swb - in the process of being torn down and born again!
jmanz69 is offline   Reply With Quote
Old 05-13-2002, 05:36 PM   #2
71402BB
now thats a true COON DOG
Post
Not hard at all! I did this 2 winters ago to my 71 swb stepside (2wd). I also have a 4-speed hooked up to it........... getting that in place was a royal B*tch. to put the 4-speed in you are going to need a 4-speed X-member out of a BB 4-speed truck. If you have anymore questions feel free to e-mail me.
71 SWB Stepside, was a 250, now is a 402 Big Block with 4 speed and 3.73's
72 LWB 4x4 350 4-speed 3.08's posi wearing army olive drab green (SOLD!)
68 BURB 50TH LOOKALIKE with built 350 4-speed 4.11's and posi
current project
67 402BB stout th350 3.08's with a locker. Plan on tubs 18.5's out back! (thanks Burnsman!)
71 SWB Stepside, was a 250, now is a 402 Big Block with 4 speed and 3.73's ( was crushed by a tree, bed sold, motor pulled) was my first truck!... oh well...
68 BURB 50TH LOOKALIKE work in progress, soon to have 250-I6 with a 3-speed on the tree 4.11's and posi ( currently sitting in back yard tarped awaiting time, $$$, and lots of love!)
67 1 TON- work truck 396 sm 420 4-speed, flat bed 4.57 gears "big red" (my first landscape truck, very rusty and crusty! but still gets the job done when needed!)
71402BB is offline   Reply With Quote
Old 05-13-2002, 09:13 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
They came with big blocks and 4 sppeds, big blocks and TH 400's, so all you need is the big block pieces.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
E-mail longhornmail@yahoo.com
My name is Andy...not Randy...I'm in Ohio...Not Illinois...close enough?
Columbus Ohio
Old 05-13-2002, 09:29 PM   #4
jmanz69
jmanz69's Avatar
Post
I have the low hump cab, will that cause a problem? I need a new one anyway so I could get a high hump. Also, I wsa thinking more along the line of a Muncie 4-spd. Would that make a difference? Thanks
Old 05-13-2002, 09:52 PM   #5
Longhorn Man
Post
I don't know 4 speeds, but if it is out of a car, you will probably have shifter location problems.
As far as the high/low hump issue, you will need the high hump, esp with both a big block AND a 4 speed. If you decide to fix your cab, all you need to do is hack out the old one, and bolt in the high hump. (it's a bolt in piece with the high hump)
Columbus Ohio
Old 05-13-2002, 10:19 PM   #6
HvyChevy454
Slowly getting CRSS...
HvyChevy454's Avatar
Post
ive got a 454 backed by a th350 in mine, no major probs what so ever
had to move everything back 2'' column shifter linkage and trans x-member. i ended up getting the not 72 bb mounts so i had to drill new holes. w/ mechanical fan and a 4 core radiator i have about 1/2'' between em. had to notch the frame just a tad to get the long tube headman headers clear sufficiently.
Lutz, Fl
My Team Website
The Heavy Chevy Website
  • 72 Cheyenne 10 LWB GM 12-bolt 3.08 w/ Auburn Posi
    91 454 Edel Intake 850 cfm carb Comp Cam 268/.500 Hedman Headers Dual 3'' Exhaust
  • 71 Cheyenne 20 4x4 Fact. A/C PS PB Tilt Currently in the works...
    Put it to the floor...
-Nic
Lutz, Fl
My Team Website
    91 454 Edel Performer RPM Intake 750 cfm carb Comp Cam 268/.495 Hedman Headers Dual 3'' Exhaust
Speak Softly and Carry A Big Block...
There is No replacement for Displacement...
"If everything seems under control, you're just not going fast enough."
- Mario Andretti
HvyChevy454 is offline   Reply With Quote
Old 05-13-2002, 10:43 PM   #7
cygnet
Post
I put a 502 in my 71 just bought the towers and mts from the general and she droped right in and I have the stock TH350 know problems yet and it's going on 3 years now
ZZ502 coral Ice pink
ZZ502 Buckets 3:73 posi coral Ick Pink
cygnet is offline   Reply With Quote
Old 05-13-2002, 10:56 PM   #8
fast_dev
fast_dev's Avatar
Post
you don't need the high hump cab with a car four speed, i have a 402 and a muncie in my 68. i used the big block motor mounts, and the bell housing mounts, that's all.
68 chevy 406 small block, budget drag racer, new best e.t 11.91 @112
67 nova numbers matching 327 4 speed 13.6 @ 102mph
70 longhorn c-30 402/4 speed
70 c-10 swb 402, muncie 4 speed
94 s-10 350/th350 3:73 posi
71 c-20 402/th400 towrig for racetruck.
72 4wd lifted on 35's
72 350/3 speed winter beater
fast_dev is offline   Reply With Quote
