Old 01-13-2009, 10:26 PM   #1
sandking
.....I am working on it.....
sandking's Avatar
5.3 4wd swap questions
I have seen alot of these threads lately, but not in 4wd trucks/Blazers. I have a few questions:
1. Motor mounts. I have seen the mounts available for 2wd, but is the 2wd the same as the 4wd? If not, what are my options? I am leaning on building my own.
2. Headers. What mid length headers work with the motor mounts mentioned above? I can also build my own, but I just cant build them for the price of the Headmans, Hookers, etc.
3. A/C. I will have the compressor on the motor. Right now, my Blazer is heat only. Besides the controls and the condensor, what else do I need to complete my cold air? Is there a kit that will work with my new compressor?
These sound like newbie questions, sorry 'bout that
View my build thread HERE
sandking is offline   Reply With Quote
Old 01-14-2009, 12:12 AM   #2
leatherhead63
Re: 5.3 4wd swap questions
I have a 72 Blazer frame with a 72 Cab and bed that has been cut down to size with a 5.3L. I could not find any after market mounts that were guaranteed to work so I had mounting pads manufactured and welded to the frame that would except standard motor mounts. I used short headers (Headman) for a 2003 Tahoe. I had to notch the frame on the passenger side. I used the existing radiator. Motor sits nice. Looks like it came that way. Can't help you on the A/C . Good Luck
leatherhead63 is offline   Reply With Quote
Old 01-14-2009, 12:37 AM   #3
sandking
sandking's Avatar
Thanks for the reply. Do you have any pics of the mounts and the headers installed?
Old 01-14-2009, 12:54 AM   #4
72truckman
72truckman's Avatar
Mounting in a 4x4 is a real PITA and ive gone through 3 crossmembers still looking for the way i want to mount it for good...
My 1972 Blazer 5.3 E85/ NV4500 5spd 4x4
Work in Progress
http://67-72chevytrucks.com/vboard/s...d.php?t=291482
****SOLD!!!!!**** 1965 GMC 4X4
http://67-72chevytrucks.com/vboard/s...d.php?t=294727
72truckman is offline   Reply With Quote
Old 01-14-2009, 09:38 AM   #5
sandking
sandking's Avatar
I will probably end up building my own stuff. I just thought maybe there was a simple way out.
Old 01-14-2009, 11:08 AM   #6
leatherhead63
Sorry no pictures yet. I did away with the cross member and had mounts welded up
Old 01-14-2009, 11:12 AM   #7
Ackattack
Ackattack's Avatar
I got an aftermarket A/C kit from Old Air. I told the guy on the phone that I had an LS1 compressor, so he didn't include that in the kit. He said I may have to order a "block" that bolts to the compressor that the lines connect to, but gave me the name of a company that should be able to help me out. Doc's Blocks btw.
Good luck.
Ackattack is offline   Reply With Quote
Old 01-14-2009, 10:20 PM   #8
sandking
sandking's Avatar
Good luck.
That makes sense. Care to tell the cost?
