Air ride question
Ok for those of you who are on bags with stock frame(no z's) my question is fully inflated how high does your front fender sit off the ground (wheel arch to ground)? also what size rim and tire combo are you running? and what size drop spindles are you running?
Thank you, Phil |
Re: Air ride question
ttt
#3 | |
![]() Join Date: Apr 2004
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
hotrodhomi, what im looking for is the measurement from the ground to the front fender when fully inflated
that still depends on your tire size ....
I guess we could just make some #'s up....
It's a catastrophic success.
![]() Join Date: Jan 2003
You could + or - the stroke of the bag your going to use to roughly determine where the body will wind up.A little project Im working on, wanted to lay frame but also wanted max travel so a little measuring and mock up determined where the bags should sit.
accepting donations
23 pages of bagged c-10's in the suspension section. I've looked through all of them several times for ideas.
1999 Yamaha roadstar 1600 chop. (in progress.) See my builds here>http://s113.photobucket.com/albums/n238/nickrp_2006/ "Ya'll can go to hell, I'm going to Texas." David Crockett |
Heres my 71 layed out. Its got 2.5 drop spindles and the wheels up front are 20x8.5 with 5.25 backspacing and the tires are 255/35/R20's. The wheels in back are 22x9.5 with 6.25 backspacing and the tires are 265/35/R22's.
1. All the way up. 2. Front wheel arch. 3. Rear wheel arch.
1. Ride height. 2. Front wheel arch. 3. Rear wheel arch.
1. All the way down. 2. Front wheel arch. 3. Rear wheel arch. Hope this helps.
Dusty |
#13 |
man , that truck looks awesome!!!
Very nice of you to take the time to post and try to help.. ![]()
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
#14 |
#15 |
Alright wdrthird, How'd you do it?
I don't want to squash this thread, do you have a build up some where? The only travel I have now is when the tires deflate daily. |
#16 |
accepting donations
Whats the setup on the rear?
#17 |
Seņor Member
We have a Suspension forum where you might get a lot more information on this topic.
#18 | |
Sorry, no build thread. First I gotta say, the air ride was already on my truck when I bought it, but the previous owner was one of my closest friends so I watched/helped with the build. The front is a basic setup, but instead of using cups on the lower control arms to mount the bags, the top of the factory lower control arm was cut out enough for the bag to pass through without rubbing, then a plate was welded to the bottom of the lower control arm and the bag bolts directly to that. The back has a homemade 4 link with a panhard bar. Theres a pretty big notch up through the bed to get down over the 22's. The bed floor was raised 5 inchs to make room for the fuel cell. The back of the cab had to be notched slightly to make clearance for the drive shaft. The exhaust runs through the crossmember to keep it from dragging. Its far from laying frame, but it will set the stock front crossmember on the ground. It still has the stock inner fenders up front. I think I have some pics of underneath the truck from the last time I had it up on the lift, but they're on my other computer, if I can get it to work long enough I'll try to dig them up. |
#19 |
sweet set-up, where in OK are ya?
#20 |
#21 |
GM ONLY BABY!!!
Mine is in winter storage, so no access right now. I wish mine was as low as WDRTHIRD.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride ![]() ![]() http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
#22 |
wdrthird, thank you very much that is exactly what i was looking for.
#23 |
I would also like to thank wdrthird. Your truck will be a role model to many here; for you have excatly what owners are looking for, including myself.
And your writting was clear and easy to understand - even though I haven't seen any damn detail pictures. J/K. Thanks for the quick responce and answering the original question. |
#24 |
No problem guys, glad I could help.
#25 |
What did you do to drop your truck wdrthird? I just checked mine and I only get 23.5" and 24" when aired out. I ran your tire size against mine and yours are .4" taller in the front and 1.3" taller in the rear. You must have a step notch because my rear diff touches the underside of the bed.
