Old 01-14-2009, 03:22 AM   #1
my70chevyc10
my70chevyc10's Avatar
Rear Springs
I read here that we could use the rear springs from a chevelle does anyone know what year they are from.
"Your trucks fast! You must have been going 120 when I passed you."
"Owning A 10 Sec Import Is Like Coming Out Of The Closet, In The End Ur Still Gay"
If for some reason i loose to a import...At least i can go home knowing the vehicle i drive drops girls panties...
my70chevyc10 is offline   Reply With Quote
Old 01-14-2009, 09:34 AM   #2
JimKshortstep4x4
Re: Rear Springs
"A" body 68-72 rear springs will work including Chevelles as well as other GM cars with the "A" body.
My friend has them on his short box and they work very well. Ride is good but load capacity is limited.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 01-14-2009, 12:32 PM   #3
Senator350
Senator350's Avatar
Re: Rear Springs
move your hangers and shackles and run longer springs from the rear of a 2wd 88-98 chevy truck. your load capacity will be increased and you won't be using car parts on a 1/2 ton capacity truck.
upgrade? not downgrade? unless it's all about show.
RN U OVR
Senator350 is offline   Reply With Quote
Old 01-14-2009, 12:47 PM   #4
Myself
Re: Rear Springs
That sound OK too but I think we're talking about coil springs here. Is this supposed to give a drop? how much?
Myself is offline   Reply With Quote
Old 01-14-2009, 01:37 PM   #5
kcjones
I wish I was a cowboy
kcjones's Avatar
Re: Rear Springs
I think drop is in the 2-3" range with stock Chevelle springs, but load capacity is diminished...why not purchase drop springs? Maybe $120 for the pair new, and they've got similar load capacity as stock.
-Kris
Met list: Cyclone,Wilson,TranzAm,extd56,hotrodhomi,mnky30,Rokcrln,Brad,JerryJones(well, his truck anyway).
kcjones is offline   Reply With Quote
Old 01-14-2009, 01:45 PM   #6
big_al_71
big_al_71's Avatar
Re: Rear Springs
I agree about just buying truck lowering springs, they are cheap enough and you are not using car parts,,,just my .02
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 01-14-2009, 01:57 PM   #7
michael bustamante
michael bustamante's Avatar
Re: Rear Springs
I read thats what cpp sends you when you order the rear drop springs for out trucks. Is this true?
1967custom
michael bustamante is online now   Reply With Quote
Old 01-14-2009, 04:35 PM   #8
lts70
1970 Daily Driver
lts70's Avatar
Re: Rear Springs
I got drop springs for the rear and they are no where near stock loading capacity. I want to find a better drop spring or just put some air bags in the back running off of a shrader valve behind the license plate. i will be watching this thread.
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance.
lts70 is offline   Reply With Quote
Old 01-14-2009, 07:00 PM   #9
kcjones
kcjones's Avatar
Re: Rear Springs
FYI, some aftermarket companies, can't remember which, offer an HD rear drop spring option. This would likely be at or near the stock load capacity. I agree the normal drop springs are not as beefy as stock, but they're closer than Chevelles, I'm positive. Chevelle springs were not designed to have 5+ inches of range in travel, nor support and additional 1000 lbs over the rear axle without breaking anything. I would only put car springs in if you never really load anything into the bed.
-Kris
