01-14-2009, 06:58 AM | #1 |
power steering box?
Will a power steering gearbox from a 67-72 bolt up on a 63 without the adapter kit?
01-14-2009, 11:03 AM | #2 |
Re: power steering box?
Without drilling new holes, to compensate for correct steering column geometry, and offsetting the box, to avoid contacting the frame rail...no.
01-14-2009, 11:12 AM | #3 |
One day...
It is possible but the bracket makes it easier.
01-14-2009, 11:38 AM | #4 |
It's Better With Nitro
X2...with the bracket, all of the engineering has been done for you.
01-14-2009, 01:16 PM | #5 |
The adpter also reinforces the frame,with out it the frame will weaken ! Do it right the life you save may be mine.
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
01-14-2009, 01:52 PM | #6 |
Thanks guys. This is the best site ever. I've been collecting parts for a year now and I'm about to start working on my truck. I've got new spindles and rotors from a 71, also the rearend. Want to do power steering while I doing the swap. I'm just waiting for my new springs to come in. Thanks again!
01-14-2009, 02:07 PM | #7 |
the power steering swap is easy . click link to see
http://67-72chevytrucks.com/vboard/s...highlight=swap
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " Last edited by slepysal; 01-14-2009 at 03:13 PM. |
01-14-2009, 02:28 PM | #8 |
One day...
isnt that the truth!!
01-14-2009, 05:49 PM | #9 |
Thanks Slepysal. I have access to a 67-72 box or a 73 up. I just thought that if the older one was a bolt on I would get it. But if not I will get the newer one. Thanks again, Dustin
01-14-2009, 07:57 PM | #10 |
Dustin, glad to hear your still picking away at your truck. Like these guys have said, the plates makes it simple!
01-14-2009, 08:18 PM | #11 |
power steering didn't come on trucks til '69 or '70 i believe
here is the one i used it is the Rez Engineering kit, cheapest price I found http://www.classicparts.com/1960-66-...ctinfo/76-979/
CHEVY ONLY |
01-14-2009, 11:12 PM | #12 |
SOLD
Location: Poorest state in America(Breaux Bridge,Louisiana)
????- even though the high pressure hose connecting to the gearbox is flared, does it still use the oring down in there?
1966 CHEVY FLEETSIDE SOLD 11-29-9 TRUCK THREAD- http://http://67-72chevytrucks.com/vboard/showthread.php?t=301368&page=2 |
01-14-2009, 11:14 PM | #13 |
Resistance is Futile
Not exactly sure what you mean 66PRO......I think mine was inverted flare down in the box. Its been awhile.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
01-14-2009, 11:24 PM | #14 |
SOLD
i think there is an oring at the base that the flare seals also/maybe?? i installed a ps kit and the hi press. conn. leaks, and i'm thinking its because there was no oring in there.
01-14-2009, 11:40 PM | #15 |
if it is flared it doesn't use an o-ring
there is a machined conical surface that the flare seats against are you sure your pump and box match?
CHEVY ONLY |
01-14-2009, 11:42 PM | #16 |
The fittings for the English theaded boxes are just inverted flare, no o-ring. I am not sure when they went metric but it was in the 80's.
TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
01-14-2009, 11:48 PM | #17 |
SOLD
thats what i thought, one or the other, thanks
01-14-2009, 11:53 PM | #18 |
SOLD
yeh, its some braided ps hoses, they are a little stiff to work with, so i might just have to take it off and check it out.
01-17-2009, 10:57 PM | #19 | |
where did you find the braided ps hoses? and do you have a picture of them connected to you're pump? thanks
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 |
01-17-2009, 11:51 PM | #20 |
Speedway sells fittings to convert the ps to Stainless Steel braid and AN fittings. Don't know if anyone is interested but thought I would mention it.
Frank
70 chevy lwb c10 454/th400 and a 9" rearend suicide doors, marker light fuel fill, 4" cowl , mini tub |
01-17-2009, 11:54 PM | #21 |
Ok I just looked it up and apparently Speedway has a few options for ps lines.
Heres the link http://www.speedwaymotors.com/street...ering+Adaptors Frank
01-17-2009, 11:59 PM | #22 | |
SOLD
i got them from CPP, $150 speedway looks a little cheeper i fixed the leak, it just took a little ol fashion teflon tape. sorry, but the fittings are hard to see due to the tight fit
1966 CHEVY FLEETSIDE SOLD 11-29-9 TRUCK THREAD- http://http://67-72chevytrucks.com/vboard/showthread.php?t=301368&page=2 Last edited by 66chevy PROSTREET; 01-18-2009 at 12:19 AM. |
