Old 01-14-2009, 08:43 AM   #1
Hilly
Hilly's Avatar
Chassis numbers
Hi Guys,
Where can i find the chassis number on a 1969 c/10 please
you need vin and chassis to reg a truck here in australia.
Hilly
Toy list
1969 RS SS BB Camaro
1969 C10 Custom on its way downunder
Hilly is offline   Reply With Quote
Old 01-14-2009, 09:07 AM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Chassis numbers
If I'm not mistaken...they are the same....it should be stamped into the driver side rail either on top or the outside area right below the door....you might need a wire wheel around depending on the shape of the chassis....it might be really hard to see with the cab is on as well....good luck!
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 01-14-2009, 09:38 AM   #3
Rack Man
Re: Chassis numbers
Mine is stamped twice...both on the drives side rail..as mentioned above & up towards the front by the steering gear....
Dan
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288
Rack Man is offline   Reply With Quote
Old 01-14-2009, 05:30 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Chassis numbers
it is only a partial VIN on the frame, ans as rack man said, 99% of them have it stamped up beside the power steering gear box.
