Old 01-14-2009, 06:03 PM   #1
70cst
70cst's Avatar
Battery Master Power Switch Lists
I have been reading threads on Battery Switches and ran across this. Its a little pricey but.... What do you all think? The good and the bad?
Paragon Products $199
http://www.paragon-products.com/prod...r%20switch.htm
This is painless...$79
http://www.vichubbard.com/auto-part-...ppp-30204.html
Hotronics...about $25-20
http://www.streetrodderweb.com/tech/...ect/index.html
Cole Hersee $20-25
http://www.ryderfleetproducts.com/cg...uct_detail.jsp
Watsons $110
http://www.watsons-streetworks.com/battery.html
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 01-14-2009, 06:20 PM   #2
lts70
1970 Daily Driver
lts70's Avatar
Re: Battery Master Power Switch
Look at this site. Cool idea.
I just did the old school switch version.
http://67-72chevytrucks.com/vboard/s...d.php?t=321757
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance.
lts70 is offline   Reply With Quote
Old 01-14-2009, 06:32 PM   #3
70cst
70cst's Avatar
One thing I noticed is the range of amperage ratings between the switches.
Old 01-14-2009, 08:56 PM   #4
70cst
70cst's Avatar
Thanks...I added it to my list.
Old 01-14-2009, 09:00 PM   #5
cparman
sharp as a marble
Re: Battery Master Power Switch Lists
what are you trying to accomplish? Look at painless wirings web site. They have a couple of setups that would allow you to use a toggle switch, from under the dash to shut down the whole electrical system, but yet retain memory to what you want. I looke at this the other day 70107 is the part number I think?
cparman is offline   Reply With Quote
Old 01-14-2009, 09:38 PM   #6
70cst
70cst's Avatar
Just looking at the cleanest options avaliable. Also I have noticed that there is a wide range of amperage ratings. There is another thread which touches on this subject so I thought it would be good to see what viable options are out there. I think I like the Watson and Painless best of the ones so far. I will end up installing one of these on the Circuit Rider. I only want to do this once.
Old 01-14-2009, 11:51 PM   #7
MickMc
MickMc's Avatar
I'm running the Watson switch in three of my vehicles.
One activated with a remote and the other two with buttons.
Even the tech guys at Watson's are helpful.
I'll buy from them again.
Mick
MickMc is offline   Reply With Quote
Old 01-14-2009, 11:59 PM   #8
texanidiot25
Eat My Rust
texanidiot25's Avatar
70-80 amp should be a pretty safe set unless your running a sound system. Most modern seem to run around that I've noticed.
texanidiot25 is offline   Reply With Quote
Old 01-15-2009, 08:53 AM   #9
70cst
70cst's Avatar
Thanks for the info....that was one of the questions that I was wondering about.
MickMc
I never thought about a remote. Interesting idea. Thanks.
Old 01-15-2009, 06:20 PM   #10
70cst
70cst's Avatar
Ok...after much reading and googling....I went with the Watson's PressTech TM Touch Pad Battery Disconnect. It looked like the most flexable plus they were very helpful on the phone.
