HERE.......Somewhere
Truck is runnin' but.....
The headlights only work on brights ONLY
Current rides: 2013 Hyundai elantra gt DD 1995 camaro my first crush lmao Was: 1970 ![]() ![]() Classics make it possible! |
Re: Truck is runnin' but.....
I would check the dimmer switch on the floor check the connections or replace it, that should take care of it at least it did when mine did the same.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
only 3
RIP BigDaddyDave ~7-23-09~ You will be missed~
I am glad its running again.
BigDaddyDave's Truck: http://www.flickr.com/photos/daves71chevy/ | See it in Action! |
its all about the +6 inches
Grandpa in the rustmobile...
DIMMMER SWITCH!!!
mine did the same thing! worked on low beam but cut off on high beam, had to drive behind gf's moms van for 10 miles home in the SNOW!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
http://shop.advanceautoparts.com/pro...pe=404&PTSet=A
Its the only one in stock is it ok cause its real cheap
Moderator
![]() Join Date: May 2007
Dimmer switch....available at any chain parts store for less than $10
yup bout 8 bucks otd
Could also just be the lamps . My '69 lost both Low Beams .
strange i would have thought your lights would only work on dim
dimmer switch....well thats what mine did when only my low beams worked
![]() 83 chevy...4x4...454 |
#13 |
Those dimmer switches are bad about getting rust on the terminals causing a bad connection. Happened on both of my trucks.
#14 |
just found out it wasnt that just both low, 2 park lamps, and both tail lights because of mexijapachin voltage reg stuck and blew em out Id rather pay 40 to 100 bucks for the original gm stuff instead of that foreigen crap and feed an american instead of a japachin.
#15 |
sharp as a marble
![]() Join Date: Jan 2007
probably the dimmer switch. Many years ago me a two friends had been to Bloomington Gold a big deal corvette show. We had taken one of the guys 62 fuelie to be judged. We left Bloomington IL. about 6:00 p.m Sunday. About 3:00A.M. we were near Atlanta Ga, and I was almost awake, and I hear OH S#$%. we do not have any headlights!! I tell them to pull over. Figured it was the dimmer switch. Told the owner of this high dollar 62 Vette to open the trailer. " what are you going to do?" Me says " you will see, give me a flat blade screwdriver". So I get the short harness from the voltage regulator to the generator and make me a jumper. Jumpered the connector at the dimmer switch in the tow vehicle. It was my turn to drive, they went to sleep. Now They call me CLETIS, cause I can rig something in an emergency. Longhorn man might be right, but dimmer switches are a high fail item
#16 |
Insert Title Here
I have a hard time believing any of your posts are real.... so im not answering
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
#17 | |
Sierra Grande Club
![]() s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
#18 |
R.I.P. E.S.L.L.
![]() ![]() Join Date: Aug 2005
1971 Custom C/20 ![]() 1970 CST 20 1970 C/30 Flatbed 1983 C/30 Dually 2015 Corvette Z51 2021 Corvette Z51 1991 Cadillac Hearse 1982 Cadillac Eldorado Biarritz 2000 Porsche Boxster S 2020 Jeep Gladiator 1973 VW Thing 1973 Plymouth Satellite wagon 1963 Baja Bug 1959 Bug Dune Buggy 1970 Baja Bug 1987 Jaguar XJ 350. R.I.P. El Jay R.I.P Jessie. R.I.P Grumpy. Every day is a gift from God. |
#19 |
lol watta story!
#20 |
![]() Join Date: Nov 2004
I thought that you were buying a gold S-10?
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#21 |
travis... all kidding aside, this is why I told you to test it first.
You don't just throw money at a problem without troubleshooting it first. You got lucky, it was a cheap part, and not some high dollar piece. |
#22 |
at least its only 7 bucks instead of a ben franklin
#23 |
exactly.
you got a cheap lesson on why you should troubleshoot instead of swapping parts. |
