Old 01-14-2009, 11:07 PM   #1
rico7769
Hybrid67
rico7769's Avatar
327 or 350
Does anyone know how to identify the diff between a 350 and 327? My casting numbers are 3970010 w/ the other identifying #'s being 5 G 7. I understand the info, but am unsure of the block size. It was put in a 67 GMC CST before I bought the truck. It would make a diff in the horsepower rating we are looking to achieve if it is a 77 and not a 67. Any help would be appreciated. We haven't checked the heads for #'s yet. We are running a perf. intake, holley 4bbl 650cfm, accel hei system, accel 8mm wires, and perf. headers. I am also curious about the HP. If it is 67 it will be greatly diff from 77.
rico7769 is offline   Reply With Quote
Old 01-15-2009, 01:43 AM   #2
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: 327 or 350
That's the same block I have. It's an early 70's sbc performance block with 4 bolt mains, and with the high nickel content. I'm sure it was used for 350's...not sure about 327's.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 01-15-2009, 02:01 AM   #3
Gray Ghost
Gray Ghost's Avatar
Re: 327 or 350
Depends on where you read about it. according to Mortec, 327's had a one year date with that block code. In the Chevy V8 casting numbers 1955-1993' book only 350's and 302's had that number.
Mortec says '69-'80 for the 010 block as a 350. I've never seen a 327 with that code so I don't know.
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 01-15-2009, 02:11 AM   #4
breeh
Recovering 67-72 Addict
breeh's Avatar
Re: 327 or 350
Did you look up the suffix code stamped in front of the passenger side head? Also, 010 blocks do not always have 4 bolt mains.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 01-15-2009, 02:14 AM   #5
Gray Ghost
Gray Ghost's Avatar
Re: 327 or 350
Two good points....most were actually 2 bolts, but that's not a bad thing at all. The suffix code will help a ton.
Kelly
Old 01-15-2009, 02:15 AM   #6
breeh
breeh's Avatar
Re: 327 or 350
You can look up the suffix code here:
http://www.nastyz28.com/chevy-engine-code-stampings.php
Old 01-15-2009, 09:38 PM   #7
68GMCCustom
Re: 327 or 350
I've heard of that block number coming up as a 327 also...but I never heard of it with 2 bolt mains. We talking about the same 3970010 high nickel content "performance block"?
Learn something new everyday I guess.
Kurt -
Old 01-15-2009, 10:21 PM   #8
rico7769
Hybrid67
rico7769's Avatar
Re: 327 or 350
Motor has been repainted and rebuilt recently so it appears the codes on the pass head (front if I'm correct) have been cleaned or painted over. Very difficult to get to w/ the water pump in the way, too. We plan on changing out the valve covers soon and will check the #'s on the head then. Maybe that will lend some info. About the high nickel block, not too sure how early it is. If the numbers G 5 7 are correct it would lend to a 77 w/ a phenominal......180hp-yeah.
Old 01-15-2009, 10:59 PM   #9
rico7769
Hybrid67
rico7769's Avatar
Re: 327 or 350
Also tried to find the date codes on the front, but it appears the the engine has been decked and I've read that decking can remove the numbers. Don't know how reputable the source was though. Just found it tooling around a diff. website.
Old 01-15-2009, 11:13 PM   #10
elkynova
Re: 327 or 350
the 3970010 block is a 350 in both 2 and 4 bolt used through 84. Used in passenger and truck lines, both low and high performance.
elkynova is offline   Reply With Quote
Old 01-16-2009, 12:49 AM   #11
sweet70beast
sweet70beast's Avatar
Re: 327 or 350
60s-mid 70s most were 4 bolts, mid70s- 80s most were 2 bolts. I had a 83 Suburban years ago with a 2 bolt 010 block.
1970 Nova 327/T5 (my 1st car)
1971 K-20 350/350/205 (winter DD)
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1972 Skylark (suncoupe)
1 of 3943 made
sweet70beast is offline   Reply With Quote
Old 01-16-2009, 01:33 AM   #12
breeh
breeh's Avatar
Re: 327 or 350
Hmmm, that has not been my experience. Especially with these trucks. All of the 2wd 1/2 and 3/4 ton trucks that I have had with that block had 2 bolt mains. For some reason the 4x4's seem to have the 4 bolt mains.
I also play with early 2nd gen Camaro's and most of those 010 blocks have 2 bolt mains as well. Maybe it is regional?
Old 01-16-2009, 07:41 AM   #13
Gray Ghost
Gray Ghost's Avatar
Re: 327 or 350
010's were factory blocks only up until 1980 according to Mortec.
Kelly
Old 01-16-2009, 09:14 AM   #14
Re: 327 or 350
Nasty Z28 doesn`t list my suffix code and I can`t even find suffix codes at all on Mortec.
My`68 327 block casting# is the same as 302 & 350 in`68.My suffix code is VI0I8YH.It`s fresh rebuilt and clean as a whistle on a stand.There is no mistaking the digits.They are perfectly clear.Any tips on finding suffix codes on Mortec?
Old 01-16-2009, 04:48 PM   #15
Re: 327 or 350
...Or anywhere else?
Old 01-16-2009, 09:53 PM   #16
red69ss
Burnouts are therapeutic
red69ss's Avatar
Re: 327 or 350
special-k according to one of my engine id books ths YH stands for 1966 model 327 220 hp ,4 bolt used in c-30 or the more likely fit 1967-68 327 220 hp ,4 bolt used in c-10 thru c-35 heres a link to nasty z28 they got there info from mortec http://www.nastyz28.com/sbchevy/sblock.php
1969 CHEVELLE SS
1972 C10 ALMOST DAILY DRIVER
1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE)
1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR)
"My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield
"The difference between genius and stupidity is that genius has its limits." - Einstein
red69ss is offline   Reply With Quote
Old 01-16-2009, 10:44 PM   #17
67slammer
67slammer's Avatar
Re: 327 or 350
my engine casting numbers are 3932386 which i found to be 69 camero and they used that same casting number for the 302 327 and the 350 the 327 was a two bolt main.
67slammer is offline   Reply With Quote
Old 01-17-2009, 12:01 AM   #18
Lugnut64052
Middle-aged Curmudgeon
Lugnut64052's Avatar
Re: 327 or 350
It's a four-inch, large journal block, and a very common one. I've seen just as many 2-bolt ones as 4-bolt ones with that block number. If it was in a passenger car, a lot of them were 2-bolts, if in a heavier truck (3/4 ton and up) they were usually 4-bolt.
The only way to tell for sure whether it's a 350 or a 327 is to pull a head and measure the stroke length. At this late date original, un-rebuilt engines are fairly scarce. Chances are it's been apart and been rebuilt at some point and if so, all bets are off. Probably a 99% chance it's a 350. There are large journal 327 cranks out there, but they're pretty scarce.
As for power ratings, it all depends on what's in it (cam, heads, etc.) All you know for sure at this point is that it's a 4-inch block.
Lugnut64052 is offline   Reply With Quote
Old 01-17-2009, 08:46 AM   #19
Re: 327 or 350
The 010 blocks can be bored 40 over.They are the best rebuild candidate.Mine isn`t an 010.It came out of a`68 CST/20 and I opened it up for the 1st time.The six says it`s a`67 according to NastyZ28.It`s a large journal.
Old 01-17-2009, 09:27 AM   #20
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: 327 or 350
Okay, this casting number....where is it located? My engine is on a stand and I know that it is the "numbers-matching" engine for my truck, per the coding on the right side of the block on the machined part....i.e., it has not been decked.
I just haven't gone to the trouble to look for it, yet....it's cold in the garage.
Member Nr. 2770
