Old 01-15-2009, 07:58 AM   #1
1969K10
1969K10's Avatar
Front ds vibration
Looking for ideas,
2WD, hubs unlocked - no vibration
4WD, hubs locked - no vibration
2WD, hubs locked - vibration. and it phases in and out. I'm fairly certain it's coming from the front.
anyone got any ideas? THX
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 01-15-2009, 03:01 PM   #2
vtblazer
vtblazer's Avatar
Re: Front ds vibration
Slip joint would be where I'd look first, then front u-joints, then...everything else.
vtblazer is offline   Reply With Quote
Old 01-17-2009, 07:09 PM   #3
CPNEJR
CPNEJR's Avatar
i had a similar problem then i grenaded the right front axle and repleced it with another one and presto! no more vibration. not sure the reason behine the grenading axle but it could've been a bad u-joint since the new axle has a new u-joint in it
(Only) Member of the CPNE Fan Club Aint that the truth
67 C-10 350 with 3-speed tranny and 308 gears swb step
82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine)
72 Chevy K20 Suburban (future project)
70 Chevy K20 now 68 GMC K2500
2003 Chevy 2500hd ccsb 4X4 (daily driver)
CPNEJR is offline   Reply With Quote
Old 01-19-2009, 07:37 AM   #4
1969K10
1969K10's Avatar
thanks for the replies! I've noticed no vibration at slower speeds, then around 50 it starts to pick up... I'm starting to wonder if the DS is out of balance. I picked it up from a junkyard when I did my T-221 to NP205 conversion...
Old 01-19-2009, 08:58 AM   #5
In that mode your wheel are turning you shafts freely,as in unengaged to the t-case.Wteh it in 4wd it`s enough to put tension on the worn joint.So,it would be either in the axle "u"s or driveshaft.Put t-case in neutral and unlock hubs to check for play in joints.You`ll be able to turn everything into whatever position.Once in position you can hold one side of the joint or lock the hubs.Stick a big screwdriver through the joint and check for slop.You should notice slop by losking hubs,grabbing the d-shaft and twisting back and forth,too.
