Old 12-07-2002, 12:09 AM   #1
neonlarry
neonlarry's Avatar
Question How to chenge to newer style alternator
2 people have showed me on their trucks, but does anyone have a pic of how to wire the newer style alternator? (and instructions of how to do it) (not the 1 wire kind).
Also, I can get a used one for free, should I just try it and see if it works, or should I have it rebuilt or get a new one? The car that it's in hasn't run for a long time, but when it did the alternator worked.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 12-07-2002, 12:28 AM   #2
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Go to any parts store and buy one that is new or rebuilt. They run around $30. Take the old one in as a core. For wiring, do a search of the topic "alternator swap" and it will pull up about 20 different strings about just this. Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 12-07-2002, 12:46 AM   #3
Blackhawkdc
440 american Horses
Blackhawkdc's Avatar
Here's a picture of the wiring conversion that was posted a while back, I forget who by.
Seth Petro
1969 Chev Short Step
425hp 350, TH400, big tires, fast truck
1979 Pontiac Trans Am
1991 Saturn SL1 - gas mileage! (and free)
1977 Buick LeSabre - for sale
May America bless God, and may God bless America
Blackhawkdc is offline   Reply With Quote
Old 12-07-2002, 12:51 AM   #4
neonlarry
neonlarry's Avatar
Thanks for the pic, I saved it so now I will have it. Does anyone have the instructions of how to do it though? I just did a search for alternator swap, and I couldn't find anything that made any sense.
Old 12-07-2002, 09:52 AM   #5
Blackhawkdc
440 american Horses
I'll check the manuals at work and figure out exactly which wire goes where on the alternator and try to get back to ya tonight.
Seth Petro
Old 12-07-2002, 10:36 AM   #6
hanssolo
hanssolo's Avatar
Mines a '69 but should be same wire colors. White and dark blue are internal now so throw them away. Red is battery. Brown goes thru firewall to ignition and into steering column (I guess for flashers). Black of course is ground. Hope this helps.
69 C10 longbed: 357c.i. /TH400/3.73s/AC/ beige primer/saving $ for paint
______________________________
hanssolo is offline   Reply With Quote
Old 12-07-2002, 06:42 PM   #7
Blackhawkdc
440 american Horses
Ok, connections at the alternator:
Dark Blue: number 2 terminal on Alternator
White: number 1 terminal on alternator
Red: Battery terminal on Alternator
Black: ground
Those are the wire connections on the newer internal reg'd alternator. CS model I believe (?) Those connections will keep the alternator working good and also keep the Alternator light on the dash functional.
Seth Petro
Old 12-07-2002, 08:39 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Yeah, you don't want to delete any wires...just re-arange them a little.
Old 12-07-2002, 10:29 PM   #9
neonlarry
neonlarry's Avatar
Ok, I think that makes a little more sense now. I think I will just go ahead and try it, and I will ask if I have any more questions.
Old 12-08-2002, 01:41 PM   #10
hanssolo
hanssolo's Avatar
If you install a new style alternator and do it right, the old regulator and at least 1 wire will be in the garbage can. Theres no need to have the old regulator on the truck anymore with jumpers on it. Hot-rod magazines have articles on how to do it frequently.
Old 12-08-2002, 11:13 PM   #11
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Plug it & go
M&H makes a neat little kit with the connectors all covered in a rubber case. Plug it into the harness that comes off the regulator and plug another onto the harness that goes into the alt...no cutting, crimping or colors to worry about. About $20 for all.
Email: frankeham@comcast.net
Phone: 360-956-7170
PICKMUP is offline   Reply With Quote
Old 12-09-2002, 02:59 AM   #12
TERRYP
GYRO GEARLOOSE
TERRYP's Avatar
Why get a a new alternator? They either work or don't. Put the free on in, if it does not work, you are out 10 minutes time, if you take the attitude that everything you put into your truck has to be perfect, you'll wind up with a $20,000 old truck instead of a $2,000 old truck
Nevada City, CA
Everett, Washington
57 3/4 rat, 235, 3spd
66 C-10 Panel, SWB. 350 from '68, 200R4 tranny, 3.07 rear ratio, restoring
68 C10 LWB 350 4spd, 4.56 rear dump runner
82 Camaro, 305, THM-200-R4
84 Monte Carlo 305 TH350, land tuna
85 Tercel SW, snow runner
DISGRACED OUTLAW MEMBER OF THE DRUM BRAKE CLUB
TERRYP is offline   Reply With Quote
Old 12-10-2002, 12:59 AM   #13
Longhorn Man
I found mine in the trunk of an abondoned Nova. Workin fine.
Old 12-10-2002, 01:35 AM   #14
neonlarry
neonlarry's Avatar
I agree about using the old alternator. There is some stuff that I will buy the best I can afford, but other stuff it either works or it doesn't.
Old 12-10-2002, 11:30 AM   #15
HotRod929
HotRod929's Avatar
Location: Bondurant, IA but in Worcester, MA for school
Blackhawkdc - so basically what you are saying is that if I replace my externally regulated alternator with an internal regulated alternator all I need to do is rearanged the wires like you said and im done? I dont have to mess with the 12v the alt. need to make power and run a wire to the ignition switch and what not? Thanks
HotRod
1970 Chevy C-20
350 V-8
Turbo 350 w/ shift kit
Dana 60 w/ 4.10 gears AND Powr-Loc POSI
New Additions:
Summit Headers
135amp alternator
Proform HEI
Edelbrock 1406 600cfm carb
Sunpro Tach
Powr-Loc POSI
Edelbrock Performer RPM Intake
MSD 6A Ignition Box
AIM: HotRod929
Visit My Site: http://1970chevy.netfirms.com/
HotRod929 is offline   Reply With Quote
Old 12-10-2002, 12:30 PM   #16
Truckstr
Truckstr's Avatar
Alternators for our old trucks turn up in the strangest places.
I was at one of those little mini-markets getting gas, when this guy walks up to me and says that he used to have one of these old trucks and wanted to know if I wanted a spare alternator for it.
Of course I said, "yeah!"
He walks back over to his car and brings one back to me. It was, in fact, the right one.
Ya just never know...
Now, that said, my '67 has a new one-wire alternator. They are available in the aftermarket rated up to something like 120 amps. If you have an A/C system, hot ignition, honkin' stereo, electric fuel pump, high powered head lights, etc., then a higher powered alternator is a better alternative than the old ones.
Jeff
Jeff
'67 short Fleet; my ongoing project.
'66 long Fleet; my original "baby."
Live life or bust trying.
Truckstr is offline   Reply With Quote
Old 12-10-2002, 11:53 PM   #17
Blackhawkdc
440 american Horses
HotRod
That's exactly it. If you notice, looking at a wiring diagram, the bypass wires actually supply the internelly reg'd alternator with exactly what it needs. Its so simple, its almost idiot proof.
Seth Petro
Old 12-11-2002, 01:30 AM   #18
HotRod929
HotRod929's Avatar
Blackhawkdc - I have a 135 amp internally regulated alternator that I would like to replace my externally regulated 35 amp alternator. Now will the wireing that is there be able to handle this alternator or am I gonna have a good smoke show on my hands?
HotRod
1970 Chevy C-20
350 V-8
New Additions:
Summit Headers
135amp alternator
Proform HEI
Sunpro Tach
Powr-Loc POSI
MSD 6A Ignition Box
AIM: HotRod929
Old 12-11-2002, 09:39 AM   #19
Blackhawkdc
440 american Horses
HotRod
For that hot of an alternator, I'd run a new wire from the Battery terminal on the alternator to the Battery itself. An 8 gauge wire should be sufficient.
Seth Petro
Old 12-11-2002, 01:14 PM   #20
neonlarry
neonlarry's Avatar
An alternator out of a 77 Monte Carlo will be ok with the stock wires, right?
Old 12-11-2002, 07:54 PM   #21
Blackhawkdc
440 american Horses
Should be. Never hurts to replace the main red wire from the Alternator to the Battery though. Electricity always enjoys a nice clean path to run on.
Seth Petro
Old 12-11-2002, 08:50 PM   #22
HotRod929
HotRod929's Avatar
Yea just got back from HomeDepot with 10 feet of 4 gauge wire for my alternator...i figured that would make it one less thing to worry about melting on the truck I still have no idea how I should hook the wire up to the battery. Its a single post battery so where can i put it?
HotRod
1970 Chevy C-20
350 V-8
New Additions:
Summit Headers
135amp alternator
Proform HEI
Sunpro Tach
Powr-Loc POSI
MSD 6A Ignition Box
AIM: HotRod929
Old 12-11-2002, 09:10 PM   #23
73stepside
73stepside's Avatar
I just done the internal regulator alternator swap. I ran a new wire from the battery post on the alt to the junction block on the fender. I done away with all of the wiring for the exteranl regulator. you don't need it plus it puts moreresistance in the system and you don't reap the full benefits of the new alt. Run the brown wire directly to the white wire for the new connector. run the red wire to the battery post on the alt and you are all done. the wire that runs to the battery junction block is 10 gauge. i got a 63 amp alt. the same amp alt as my old ext reg unit when i hooked it up through th ext reg harness, i wasn't getting any charge to the battery. so i did it this way, and it runs much better. i ran a search on the board for alternator and found the conversion in both configurations.
04 GMC Sierra RCSS
70 CST LWB
04 HD Sportster 1200 Custom
73stepside is offline   Reply With Quote
