Old 01-15-2009, 03:43 PM   #1
Knothead
Knothead's Avatar
Dimensions for Bed Wood?
I have some rough lumber & contemplating making my own. The cross sill bolt holes are spaced @ 4'' , 5'' , & 7'' for a total of eight boards & seven strips.This is a short bed.
Knothead is offline   Reply With Quote
Old 01-15-2009, 03:50 PM   #2
bretcopsey
Re: Dimensions for Bed Wood?
click here:
http://www.gmcpauls.com/47-72_BedWood_Info.htm
My 51 project
http://www.cardomain.com/ride/2285825
My 68 Camaro project
http://www.cardomain.com/ride/2277404/1
bretcopsey is offline   Reply With Quote
Old 01-16-2009, 04:13 PM   #3
Knothead
Knothead's Avatar
Perfect , Lots of good info ,Thanks
Old 01-16-2009, 11:51 PM   #4
blackdiesel
blackdiesel's Avatar
Dont be afraid to get creative. Here is the bed i just put in my '57. it is 3/4 inch cherry, 1/4 walnut, 3/4 inch ash, 1/4 inch walnut, repeat. Notice all the boards are the same width, i think it looks better this way. also it is a strip short... i had to delete one because of where the gas filler cap came through the floor. Sorry for the water spots, it was just washed. With no time to detail it.
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
http://67-72chevytrucks.com/vboard/s...light=speedway
blackdiesel is offline   Reply With Quote
Old 01-17-2009, 11:28 AM   #5
Knothead
Knothead's Avatar
That's way cool,I like to see custom ideas. Now I some more options?
Old 01-17-2009, 01:04 PM   #6
Knothead
Knothead's Avatar
Blackdiesel ,How did you secure strips to form each board?
Old 01-17-2009, 01:12 PM   #7
blackdiesel
We also have a full custom cabnet shop. My dad used to be vocational instructor. As far as the wood goes, i planed the ash and cherry to 3/4", then resawed the walnut to 1/4". Then i ripped strips to 1 1/8". Then i turn all of them on their edges and used a good weather/water proof glue, i glued all of the peices together. Then planed each board down to 3/4" and cut the correct grooves for the stainless strips to hold the wood down. Then sprayed them with an automotive clearcoat on all sides.
It took 3 times as much wood, and approx 10 man hours. But i wanted something different.
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 01-17-2009, 01:16 PM   #8
Knothead
Knothead's Avatar
Yea ,It looks time consuming,but the outcome is well worth it,Great job!
