01-15-2009, 05:06 PM | #1 |
78 to 63 steering column swap
I'm sure this is addressed some place here that I can't find but we've completed installing a 78 chev steering column in a 63. I've looked over wiring diagrams for both the 78 and the 63 and can't seem to place 2 of the 7 wires. Any one done this swap?
01-15-2009, 05:10 PM | #2 |
TexasBowhunter
Re: 78 to 63 steering column swap
I swapped a 77 into a 66, but I used the 77 wiring harness.
Build in progress for son's first truck. |
01-15-2009, 05:55 PM | #3 |
Resistance is Futile
What wires? I think the newer columns had more acc power. Im guessing as I have been straightening out this swap in my 'burb; done by PO.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
01-15-2009, 08:05 PM | #4 |
There are 7 wires coming to each pigtail. The wire harness from the 78 column
has 7 and the 63 pigtail from the main dash harness has 7. They are for the directional signals, stop light, haz light and a seperate black for the horn. I was just going to cut the connections off the ends of each group of wires and tin them together if I can find the correct combination. The wire colors are different. Last edited by 63Belair; 02-27-2009 at 12:48 AM. |
01-15-2009, 11:33 PM | #5 |
I think all will work correctly, as the functions of the old and new harness are the same. I would crimp on spade connectors and hook it up; if you have any bad or crossed connections you can just unplug them and try a new combo....test it and get it right.
01-16-2009, 01:50 AM | #6 |
here is a 64 diagram
green(right) and yellow(left) are rear turn/brake wires dark blue(right) and light blue(left) are front turn white goes to the stop lamp switch brown goes to the horn purple goes to the turn flasher maybe that is close to your '63 wiring? i have a pdf file for my '80 (should be the same as a '78) green(right) and yellow(left) are rear turn/brake wires blue(right) and light blue(left) are front turn white goes to the stop lamp switch purple goes to the turn flasher brown is hazard flasher(you won't need) black is horn 1980 wrg diag 01.pdf 1980 wrg diag 02.pdf
CHEVY ONLY Last edited by joe231; 01-16-2009 at 02:00 AM. |
02-17-2009, 05:52 PM | #7 |
Thanks, I think I got it. I've been working off a wiring diagram from my 63 Belair which is the same as the 64 pick-up diagram posted here.
