Old 01-15-2009, 05:35 PM   #1
Irishpilot
How to tighten up bags for cornering?
Alright, so I've come to the conclusion that I need valves for each bag. I have valves for the front and rear, and the truck really leans when I corner because of the transfer of air between bags. So, how much will the bags resist leaning if I get valves for each? I also need a sway bar in the front, which I assume will help this problem out. I like to run low, and this causes the bags to be pretty low on pressure. What have you guys done to tighten it up? I'm not looking for corvette-like cornering, just no more leaning!
1971 C-10, 406ci, restoration begun!
406ci sb; zero decked, bored .030, edelbrock aluminum e-tec heads, edelbrock performer RPM intake, comp 268 cam, comp 1.6 pro-magnum roller rockers, MSD street fire HEI, MSD 8.5mm wires, Holley Street demon 770, Hedman LT headers. 10.6:1 compression, Air Ride Tech bags on all 4-corners.
Irishpilot is offline   Reply With Quote
Old 01-15-2009, 08:37 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: How to tighten up bags for cornering?
Just add 1 fill and 1 dump on each bag. Then install a sway bar. That should make a world of difference!
Keith
Convert to disc brakes.
Old 01-15-2009, 08:39 PM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
First thing is get a sway bar. Get an 1 1/8" off of a 3/4 ton truck or an aftermarket unit. It WILL make a difference. Next, is get at least two more valves to isolate your front. It would be best to isolate all corners but you def want to stop air transfer up front.
I have never done it, but I have been told that trimming, or removing your cups (assuming you have front cups) will allow you to go lower. Consequently it will take more air to ride low so your bags should have more pressure and not be so squishy.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-15-2009, 10:42 PM   #4
Irishpilot
Thanks guys! I figured that is what I would have to do. As a info note, I get more looks with the truck bagged than I do with my Corvette! That is no joke...there are so many guys that come up and tell me that it reminds them of a '67-72 that they have/had. Here is a pic of it a few weeks ago here in Utah.
Old 01-15-2009, 10:47 PM   #5
lolife99
lolife99's Avatar
That's a good looking truck!
Keith
Old 01-15-2009, 11:35 PM   #6
andrewmp6
Front sway bar is a must no matter what springs or bags you use.That is one nice looking truck.
andrewmp6 is offline   Reply With Quote
Old 01-16-2009, 01:51 AM   #7
leftcoast66
leftcoast66's Avatar
I've heard put the valves as close to the bag as possible, or directly ontop if possible, because it will keep the air from going back into the line under hard cornering rather than staying in the bag.
leftcoast66 is offline   Reply With Quote
Old 01-16-2009, 11:47 AM   #8
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
Or you can install check valves at each bag to help with the weight/air transfer.
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 01-16-2009, 12:04 PM   #9
theyammieguy
accepting donations
theyammieguy's Avatar
You have a sweet ride. Can't wait till I can bag mine.
1999 Yamaha roadstar 1600 chop. (in progress.)
See my builds here>http://s113.photobucket.com/albums/n238/nickrp_2006/
"Ya'll can go to hell, I'm going to Texas."
David Crockett
theyammieguy is offline   Reply With Quote
Old 01-16-2009, 12:34 PM   #10
Frizzle Fry
Frizzle Fry's Avatar
8 valves, 1.25" bar up front, Helwig style or late Camaro rear bar and you be grinnin from ear to ear. Cut cups and good shocks wouldn't hurt either. That's the setup I ran for some time on my 69 Burb. It held the road pretty well considering it was a 2 ton rig with a 127" wheelbase.
Frizzle Fry is offline   Reply With Quote
Old 01-16-2009, 08:17 PM   #11
Irishpilot
Thanks for the compliments on the truck! I've decided to get eight valves and definitely a sway bar. I have a lot of hp going through the truck and it would be nice to stay in the throttle around some corners instead of slamming the breaks and feeling like I'm in a '72 Cadillac.
Do you guys know if the supertrack bar from ECE is all I need back there? I've got that now, so I'm not sure if there is somehing else to go back.
Old 01-17-2009, 03:48 AM   #12
andrewmp6
About how much power you go i would think about bigger brakes if its a lot.
Old 01-17-2009, 04:00 AM   #13
Frizzle Fry
The track/panhard bar does not provide any anti-roll/sway. All it does is keep the rearend centered (or close to it). There are sway bars you can install in the back for anti-sway that are totally seperate/different than a track bar.
Search this forum for "Camaro Rear" or "Rear Sway"
Old 01-17-2009, 12:35 PM   #14
Twisted Minis
Twisted Minis's Avatar
A nice set of shocks will make a world of difference. It's incredible the difference when you switch from a Monroe or KYB to a Bilstein. Bilstein has a new line of shocks meant specifically for air ride. After putting them on a few vehicles, I won't run anything but on a vehicle of my own.
If you can find it cheaper, I can fix it!
Twisted Minis is offline   Reply With Quote
Old 01-17-2009, 02:03 PM   #15
gringoloco
A guy with a truck
gringoloco's Avatar
Do you have a link? I can't seem to find them.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 01-18-2009, 12:03 AM   #16
Twisted Minis
No. Bilstein's site doesn't have much on it. I've been playing with them for a while and I like them. I could probably answer some questions based on experience. RCD Suspensions has Bilstein build them specifically for them.
Old 01-18-2009, 12:21 AM   #17
N2TRUX
Happy to be here
N2TRUX's Avatar
..... RCD Suspensions has Bilstein build them specifically for them.
So is RCD who you get yours through, or do deal with Bilstein direct?
Articles-
"Refining Sierra"
Old 01-18-2009, 12:45 AM   #18
Twisted Minis
I get them through RCD since Bilstein makes the shocks for them. Bilstein doesn't sell them to anyone else from what I understand. I am an authorized distributor for them, but they still come from RCD. I have a chart at the shop with a breakdown of them. I will try to remember to grab a picture of it. It's basically just a Bilstein shock with valving designed for air ride. It's more progressive than your standard shocks. Since the air bag gets softer when the pressure is released, these get more firm as they compress more.
Old 01-18-2009, 12:25 PM   #19
N2TRUX
Happy to be here
N2TRUX's Avatar
Cool. Post up the details when you can.
Articles-
"Refining Sierra"
Old 01-18-2009, 01:02 PM   #20
Twisted Minis
I sent Steve an email, he said he created a page on their site recently for the air ride shocks. He sent me this link, so this should be all the info you need.
http://www.racecardynamics.com/class...ag/airride.htm
Old 01-18-2009, 01:37 PM   #21
SCOTI
SCOTI's Avatar
Nice link. I did Bilsteins on my 68. The rears required using 88-98 rear shocks w/some driveway made bracketry. One of those p/n's would have been much easier.....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-18-2009, 08:00 PM   #22
edflores
where do we find pricing?
edflores is offline   Reply With Quote
Old 01-18-2009, 08:10 PM   #23
Twisted Minis
Call me or any of the other authorized distributors.
Old 01-20-2009, 11:17 AM   #24
c10addict
c10addict's Avatar
If you dont have the cash for everything right now START with the sway bar... My 64 only has front and rear control and did not have a sway bar... I would start blowing the rockers off of it going through corners lol... I called ADDCO and ordered a sway bar and it is great now... A world of difference! I have a set of valves I bought and haven't put them on yet just because it handles great with the sway bar..
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08
67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast.
64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten..
54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread...
07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind..
http://67-72chevytrucks.com/vboard/s...d.php?t=339340
See pics of my trucks in my profile
c10addict is offline   Reply With Quote
Old 01-20-2009, 12:28 PM   #25
gringoloco
A guy with a truck
gringoloco's Avatar
Grant has them for $90 each...
-Chris
