01-15-2009, 09:50 PM | #1 |
1962 chevy c10 hazard lights
I'm a newbie - i can't find my hazard light switch. Do ant one have a wiring diagram and/or instructions on where should i begin looking for the wires?
thx |
01-15-2009, 11:00 PM | #2 |
Re: 1962 chevy c10 hazard lights
Unless some one added them as an aftermarket they were never installed.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD |
01-15-2009, 11:55 PM | #3 |
Emergency flashers were available as an R.P.O. on the '60-'66 Chevy trucks. They plug into the factory harness, so there is no evidence of emergency flashers, if they were not a factory or dealer option, previously installed on the truck.
01-16-2009, 12:11 AM | #4 |
Thanks, for the quick response. What type of after market hazard swith do you(r) reccomend?
Thx. |
01-16-2009, 12:58 AM | #5 |
here is ours
CHEVY ONLY |
01-16-2009, 01:05 AM | #6 |
Awesome!!! Do the hazard switch tie in to the head light switch? and/or the wires leading to the hazard switch?
01-16-2009, 01:10 AM | #7 |
no, it plugs inline with the steering column plug(turn signal switch) and a power wire to the fuse-box.
there is a light bulb in the red part you pull out that flashes with the hazards I agree, it is very cool IMO!!
CHEVY ONLY |
01-16-2009, 09:15 AM | #8 | |
"Where were you in '62?"
Was reverse lights an option in 1960-1963? I think it was. I just put a pair on my truck with a toggle switch, but I'm thinking it was an option.
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
01-16-2009, 09:18 AM | #9 |
as far as know, '66 was the first year for reverse lights
CHEVY ONLY |
01-16-2009, 09:23 AM | #10 |
My dad had either an 64-66 stepside with a camper shell on the back, and I remembered seeing pictures with the reverse lights on the rear fenders itself. Was that how they came?
01-16-2009, 09:27 AM | #11 |
i found previous post by Tony in another thread
by searching, i also found that some step fenders have indentions for back-up lights
CHEVY ONLY Last edited by joe231; 01-16-2009 at 09:36 AM. |
01-16-2009, 11:30 AM | #12 |
i added revers lights with using a toggle switch as well. I need to figure out the best way to add hazard lights.
01-16-2009, 11:36 AM | #13 |
i also discovered that the previous owner added later model steering column.
Scenario: hazard light switch is on the column, and it doesn't work, however, when i engage the turn signal switch, the indicator light begin to flash, when i engage the hazard switch the turn signal indicator light stops working. |
01-16-2009, 11:51 AM | #14 |
to get the newer flasher switch to work you need to add another flasher for the hazards.
can you post a pic of the column... i believe all it would take is a all time hot supply (with a flasher in series) to the hazard switch...... if the column is like my stock '80, should be a brown wire coming from the column
CHEVY ONLY Last edited by joe231; 01-16-2009 at 11:52 AM. |
01-16-2009, 12:09 PM | #15 |
i'm new @ this. my control panel do not have an option for me to upload pic. Please advise.
thx |
01-16-2009, 12:13 PM | #16 |
some how or another i managed to upload column pic thru my profile.
i'm still researching how to upload pic. |
01-16-2009, 12:15 PM | #17 |
in the quick reply at the bottom of the page, click on go advanced,
then click on this if you are uploading from your computer or this if you are using a pic that is online should be self explanatory from there. if you are uploading from your computer, make sure the pics aren't too big. if they are you can get a sweet image re-sizer HERE ask away if you have problems
CHEVY ONLY Last edited by joe231; 01-16-2009 at 12:15 PM. |
01-16-2009, 12:17 PM | #18 |
does it have wiper controls or cruise on the turn signal stalk?
CHEVY ONLY |
01-16-2009, 12:42 PM | #19 |
no wiper or cruise in the column
01-16-2009, 12:50 PM | #20 |
cool, should be a brown wire for the hazard flasher
CHEVY ONLY |
01-16-2009, 12:53 PM | #21 |
column pic
01-16-2009, 01:04 PM | #22 |
Where/what do i connect brown wire that u r suggesting
01-16-2009, 09:05 PM | #23 |
connect it to 12v all time hot with a flasher in series
CHEVY ONLY |
01-16-2009, 09:28 PM | #24 |
Understood.
Scenario - I locate the brown wire. 2 wire flasher socket - attach one wire to a constant hot N the other wire to the brown. |
01-16-2009, 11:42 PM | #25 |
yes, be careful though I have seen a plug with 2 brown wires, not sure what that is about. and make sure where you are getting power from is fused, or put a fuse in line with the brown wire. 10a or 15a should suffice.
let me know how it turns out
CHEVY ONLY |
