01-16-2009, 12:36 AM | #1 |
how to plug oil pressure line
i took my gauges out to install a white face gauge kit.. and the truck is getting a color change so they are out and i pulled truck out and i come back and i gotta puddle of oil by the driver pedal...how do i plug this so i dont leak when i want the engine to run because while the truck sits while we fix the rust and get it painted i dont want the carb to gum up
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
01-16-2009, 12:42 AM | #2 |
Re: how to plug oil pressure line
take the fitting out of the block and put a plug in it
01-16-2009, 12:43 AM | #3 |
Gone to greener pastures
You could probably pull the fitting @ the back of the block & put in a pipe plug.
Should be 1/8", I believe. That way nothing gets bent up, or crimped in the cab.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck Last edited by El Jay; 01-16-2009 at 12:44 AM. |
01-16-2009, 12:45 AM | #4 |
Awwwwwww, Man,
You posted while I was typing, that ain't fair.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
01-16-2009, 12:46 AM | #5 |
remove the other end of the line from the block and install a npt pug
Brock396 |
01-16-2009, 12:49 AM | #6 |
thats ok. two people posted while i was typeing
01-16-2009, 12:51 AM | #7 |
oh ok well it ran for 5 minutes so it should be good for another week or two.. now would be a good time for me to sand where it was
01-16-2009, 08:57 AM | #8 |
I've never had a plug when I needed it but I did have an extra gauge. Very handy when you prime the engine before you start if for the first time after rebuild too.
01-16-2009, 12:28 PM | #9 |
1970 Daily Driver
That what I do as well. I have an extra oil gauge that I just screw on in the cab after I take out my cluster.
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. |
