![]() Join Date: Feb 2008
Instrument Cluster Wiring Harness Question???
I'm wiring in my Autometer Gauges and I got the Color Wiring Diagram from this site but I have a question...
What are these wires for?? -TERMINAL BY BATTERY (black wire) -FUEL GAUGE as opposed to the FUEL GAUSE FEED -HEATER LAMP Can I tap my Volts gauge into the ALTERNATOR wire (I dont have the paper in front of me but I think thats what it says on the diagram) or is there something difference because of AMPS vs. VOLTS??? Thanks!! Im making progress....hopefully next time (or one of the next times ![]() |
"THE GREEN GOBLIN"
Re: Instrument Cluster Wiring Harness Question???
The Black wire with the fuse holder is for the ampmeter. There is another one on the other side . The other one (without fuse in it) is a fuseable link. Goes from junction block beside battery to the POSITIVE terminal on the battery. It is a slow burn fuse. In the Picture the Red arrows point to the Black wire with the fuse holder for the ampmeter ..And The Blue Arrows point to the The other one without the fuse the fuseable link.. I also Circled where that wire is on the diagram hope this helps Hope this helps
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net |
maybe these are the same wires but I was talking about the harness that plugs into the back of the instrument cluster.....
![]() Join Date: Jan 2001
That's for the ammeter in the trucks equipped with gauges and not idiot lights.
