Old 01-16-2009, 05:33 PM   #1
theyammieguy
accepting donations
theyammieguy's Avatar
proportioning valve question
I did a quick search and found this thread on the correct proportioning valve so Im assuming I have the wrong one.
I have a 68 with front disc and rear drums and my question is, is this the right proportioning valve? If not which years will work? Im headed to the junk yard tomorrow.
Here's the thread I found with I think is the right valve.
http://67-72chevytrucks.com/vboard/s...d.php?t=241722
Here's the one I have.
1999 Yamaha roadstar 1600 chop. (in progress.)
See my builds here>http://s113.photobucket.com/albums/n238/nickrp_2006/
"Ya'll can go to hell, I'm going to Texas."
David Crockett
theyammieguy is offline   Reply With Quote
Old 01-16-2009, 05:47 PM   #2
john
member #16
john's Avatar
Re: proportioning valve question
What you have is a distribution block used on drum brake trucks. Pre 1971. The prop valves shown in your link are the right ones.
john is offline   Reply With Quote
Old 01-16-2009, 05:48 PM   #3
theyammieguy
accepting donations
Right on, thanks man. Can I use any year prop valve or does it have to be a specific year?
David Crockett
Old 01-16-2009, 09:08 PM   #4
airdale94
airdale94's Avatar
The link is corect for front disc with power assist. Since you don't have power the one you have may be the corect one. Notice how your front lines are as big as your rears. Do you know if they are factory disc no power? This was just covered on thread not long ago. And I don't know for sure.
airdale94 is offline   Reply With Quote
Old 01-17-2009, 02:12 AM   #5
texanidiot25
Eat My Rust
texanidiot25's Avatar
If your truck originally had manual brakes, and you didn't swap the MC and p-valve, then technically no, it's not setup right. Yes it will work, but not to it's full potential. Disk brake MC's have a bigger front brake reservoir and flow more fluid to the front disk, since of course their cylinder takes more volume to push the brakes than the rear drums.
texanidiot25 is offline   Reply With Quote
Old 01-17-2009, 03:29 PM   #6
theyammieguy
accepting donations
Mine is a 68 so it didnt come with disc.
David Crockett
Old 01-17-2009, 03:31 PM   #7
theyammieguy
accepting donations
I didnt do the disc conversion and Im willing to bet that is the original mc.
David Crockett
Old 01-17-2009, 04:12 PM   #8
cdowns
cdowns's Avatar
easiest is probally go with a 71 or 72 master cylinder combination valve and prebent brake lines//having the 2different sizes of brake lines is very important for proper operation
Old 01-17-2009, 05:06 PM   #9
theyammieguy
accepting donations
Thats what I was thinking.
Guess I need to try and locate one.
David Crockett
