Old 01-16-2009, 08:18 PM   #1
willett
Another Day, Another Dollar
willett's Avatar
need online recource for 3\16 airline, and fittings
hey guys
does anybody know of a website that sells airlines and fittings?
i ask because i'm hooking up my airbags and i'm short a few parts
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 01-17-2009, 01:21 AM   #2
VA72C10
VA72C10
VA72C10's Avatar
Re: need online recource for 3\16 airline, and fittings
Originally Posted by willett View Post
hey guys
There are several places online including ebay and I'm sure someone else will chime in with a link, but it may make more sense to go to a local big rig supply store or a local customizing shop that does a lot of air suspensions. that way you can pick up an extra fitting or two if you end up finding something you need or doesn't work.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 01-17-2009, 01:27 AM   #3
FnLow69
FnLow69's Avatar
FnLow69 is offline   Reply With Quote
Old 01-17-2009, 01:42 AM   #4
Shane
Shane's Avatar
never seen 3/16" line in DOT style that is commonly used in air suspension systems. Not saying it doesn't exist, only that I'm not familiar with it. 1/4" - 3/8" - 1/2" are the most common sizes.
Shane is offline   Reply With Quote
Old 01-17-2009, 06:44 AM   #5
fast75
Go Hard or Go Home!
fast75's Avatar
try stylinconcepts.com
75 short wide 350, some mods, scare the piss outta ya quick.
2008 Dodge crew cab. YEAH, it's got a hemi, your ass is going to jail quick.
Some day's, it's just not worth chewing through the restraints................................
fast75 is offline   Reply With Quote
Old 01-17-2009, 08:38 AM   #6
jlaird
jlaird's Avatar
Do you need it for bags or gauges? 1/8" is what is used for gauges. I've never seen 3/16"
jlaird is offline   Reply With Quote
Old 01-17-2009, 09:57 AM   #7
vin63
It's Better With Nitro
vin63's Avatar
If you're absolutely set on 3/16" line and fittings, you can just use commonly available brake lines and fittings that should be found at any autoparts store.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 01-17-2009, 11:12 AM   #8
jlaird
jlaird's Avatar
...assuming he wants to go with hardline...
Old 01-17-2009, 12:38 PM   #9
vin63
vin63's Avatar
...at 3/16" lines, I don't know if any other alternative, do you? He could run a -3 AN flex brake line at custom lengths, I guess. It's a tough one either way.
Old 01-17-2009, 05:49 PM   #10
theyammieguy
accepting donations
theyammieguy's Avatar
It's hard to find.
Only place I see it on the trucks I work on is from the tranny up to the splitter valve on the shifter.
1999 Yamaha roadstar 1600 chop. (in progress.)
See my builds here>http://s113.photobucket.com/albums/n238/nickrp_2006/
"Ya'll can go to hell, I'm going to Texas."
David Crockett
theyammieguy is offline   Reply With Quote
Old 01-17-2009, 09:09 PM   #11
XXL
Seņor Member
XXL's Avatar
If Parker doesn't offer it, you're probably out of luck.
XXL is offline   Reply With Quote
