truck addict
what to use for drag blocks
jsut as the title says.. i am in the prosess of bagging my truck and when all is said and done i wanna be able to drag it down the freeway. but i don wanna kill my frame. whats the best thing to use and where are the key places to put them.. i planned on using titanium but i wanna know if there is anythign else i can use
trucks |
Georgia Boy
Re: what to use for drag blocks
I would say use magnesium, but that catches fire..
Might be better to just use plain ol steel.
81 GMC High Sierra, 2WD, 357ci/700R4, 3.73s, posi. |
Happy to be here
![]() Join Date: Mar 2000
The most common item used is trailer balls. They are cheap to buy, and easy to replace.
I don't think these pills work
thats what my buddy did just a trailer ball upside down on a crossmember he built
SQUARE84 ![]() 90 SUBURBAN |
Better not hit any kind of pothole with that trailer ball draggin... that might be funny.
![]() Join Date: Apr 2004
That's the best way to kill someone driving behind you. Please don't use this.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
2WD 4 Life
how do you figure it woould kill someone??? the trailer balls are something you can torque down unlike most half assed ideas i've seen on mini trucks... plus if your draggin the ass of your truck with someone close behind you are retarded. thats my .02
Big D 1969 c10 1960 cadillac 1978 king cobra |
the pollock
well yeah you can also always anglr the trailer back towards the rear of the truckso instead of catching it would merley deflect any sort of pot hole speed bump small dog or old women..
and IF you wanted to be suuuper precautious u can always greab a castelated nut and a cotter pin and dril the thread sie of the ball so the nut will never loosen... and titanium is expensive and i havent seen it spark before.. so if u dont use a trailer ball.. use plain old steel stock..
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
the problem with trailer balls is that they break where they neck down. look on utube for videos.
Here's what titanium looks like, it's supposed to make the most and brightest sparks.
Get you a 15k rated trailer ball, it won't break, but something else will. |
Happy to be here
I'm not suggesting using trailer balls, or anything else for that matter. I think it's un-safe and could cause accidents.
As much as I like lowered trucks, I don't condone dragging. I don't like dragging because it's destructive in nature, and I don't like anything that might cause damage to my truck.
2WD 4 Life
i work with only titanium at work everyday... sparks so bright and hot that it hurts your eyes. AND its very spendy
#13 |
dang its hot
why would anyone do this?
#14 |
Crew Cut
rude neighbors.lol
85 SWB 1/2 TON CREWCAB/5.3 03 CHEV 3500 DURAMAX CREW CAB 85 CHEV SWB/TPI 06 CHEV TAHOE (WIFES) 30 MODEL A HOT ROD 07 HARLEY DAVIDSON BAGGER 09 STREET GLIDE AN ![]() |
#15 |
Happy to be here
It's the look at me mentality. The same reason you see guys with bagged trucks driving down the road with the front up and the rear scraping. They want attention, and this gets it.
#16 |
![]() Join Date: Mar 2005
I don't understand the whole concept of dragging, especially at freeway speeds when you need to have the most control. Most all of my stuff is lowered, and I take great steps not to drag anything. I'm not into tearing my stuff up, no matter how "cool" it looks.
#17 |
Crew Cut
to some point we all want attention. thats why we love to restore,rebuild, fix up, ratrod um, chop, cutup, cut down. or what ever makes us happy. that is the sweet part. do it or build it the way you like and then show it to every one. if every body had a clean square truck,same color,same ride height,same tires and wheels and same etc. there would be no need for this board.
#18 |
trailer balls are very dangerous.. if u dra them enough the part where ther threads are will fall out of the hole and back behind u damaging the vehicle behind you
also u hit a hole of a bridge ledge while dragging it will ruin your frame by tearing the metal seen it happen ***************** has drag blocks made to bolt to your frame prolly the safest drag block. an then u have titanium.. brightest spark andit also last the longest but of course it is the most expensive and hardest to get drilled and tapped then u could always plate your frame with 1/2" steel plate welded to your frame. ive seen people go out of control by draging but if you know how to drag correctly there is't problems |
#19 |
dang its hot
I wasn't dissing, just scratching my head...
