Old 01-16-2009, 10:47 PM   #1
82Cecil
82Cecil's Avatar
McGaughy 2.5 drop spindles rub lower ball joint pics
Using stock ball joints
rims are 15"
I'm wondering if I did something wrong because, no where does it say I can't use a 15" rim.
82Cecil is offline   Reply With Quote
Old 01-16-2009, 11:29 PM   #2
boatpuller
boatpuller's Avatar
Re: McGaughy 2.5 drop spindles rub lower ball joint
that's the same place my 3 inch belltech spindle's rubbed with stock 15 inch rally's.i went to 17's.
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 01-17-2009, 12:29 AM   #3
heavychevy79
Cheyenne Super
heavychevy79's Avatar
Those arn't stock wheels for that year truck.
Steel wheels will fit.
heavychevy79 is offline   Reply With Quote
Old 01-17-2009, 12:40 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Welcome to the forum 82Cecil. As mentioned, your issue is the wheel you have on your truck. You can grind your a-arm a bit or get a wheel with less backspace or larger diameter.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-17-2009, 01:02 AM   #5
Cyclone
Cyclone's Avatar
Spacer?
Cyclone is offline   Reply With Quote
Old 01-17-2009, 01:13 AM   #6
82Cecil
82Cecil's Avatar
Thanks for the welcome ! and all the advice too. I'll measure the back spacing tomarrow, I would love to solve the problem with less back spacing and stay with a different style 15" wheel.
Old 01-17-2009, 03:59 AM   #7
cochino12
It followed me home?
cochino12's Avatar
Just grind it a little and you will be fine
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 01-17-2009, 06:18 AM   #8
fast75
Go Hard or Go Home!
fast75's Avatar
i have three inch drops from DJM, i just did a little grinding and the 15 inch cragars fit fine..............
75 short wide 350, some mods, scare the piss outta ya quick.
2008 Dodge crew cab. YEAH, it's got a hemi, your ass is going to jail quick.
Some day's, it's just not worth chewing through the restraints................................
fast75 is offline   Reply With Quote
Old 01-17-2009, 08:43 AM   #9
S10Fan
Old Heap Driver
Originally Posted by Cyclone View Post
Spacers would be great, finding a suitable wheel stud (longer) is a problem. I've been looking for several months, nothing but racing studs (way too long) can be found.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 01-17-2009, 11:07 AM   #10
bigblock73
yeller
bigblock73's Avatar
ARP will make them to your specs, at a cost of 8-10 a piece...I looked or a long time too couple years ago.
bigblock73 is offline   Reply With Quote
Old 01-17-2009, 11:39 AM   #11
boatpuller
boatpuller's Avatar
that isn't alway's the case.mine rubbed,and several other member's did also.some have not however.like n2trux posted,it can depend on backspace and rim width.if you search back thru some older post's,you'll find there's really no pattern to rub issue with stock rim's.
Old 01-17-2009, 12:18 PM   #12
82Cecil
82Cecil's Avatar
I measured back spacing on the non original rim I'm trying to use, but to be sure I did it correctly, I'm posting a pic of how I did it.
Old 01-17-2009, 01:02 PM   #13
lolife99
67-72 parts collector,…
lolife99's Avatar
Actual backspacing is measured (when ordering wheels) from the outer-most lip. You are down on the bead surface.
I would just trim the a-arm a little.
Keith
Convert to disc brakes.
Old 01-17-2009, 03:49 PM   #14
Slammed '87
Slammed '87's Avatar
I would have to say that there is a problem. The whole idea of a 2.5" drop spindle rather than a 3" is to avoid that rubbing problem with 15" wheels. If there isn't a problem and it does rub, the solution is simple, as was suggested, trim the a-arm down, or use a 1/4" spacer. I have done both with no issues. I try to avoid spacers if possible tho.
If you can't rock the roads with your bumpers 1/2" off the ground, you're nowhere near low enough!
Slammed '87 is offline   Reply With Quote
