01-17-2009, 01:38 AM | #1 |
Steering Wheel Clearance
I just purchased a re-manufactured wheel for my '63 along with a new turn signal switch and upper bearing with horn wire.
When I go to put the steering wheel on, I'm having the same problem as I did with the old jank that was in there before; the back of the steering wheel hits the turn signal switch outer metal housing. Every time you turn the wheel, the two surfaces scrape. I believe the outer metal housing is on correctly since it locks in place onto the column shaft tabs. Has anyone experienced this or knows what the deal with this is?
TimC63 |
01-17-2009, 01:15 PM | #2 |
Re: Steering Wheel Clearance
does it rub all around or just the top?
could be the lower bearing worn, causing the shaft to not be at the correct angle, parallel to the housing
CHEVY ONLY Last edited by joe231; 01-17-2009 at 08:12 PM. |
01-17-2009, 01:39 PM | #3 | |
As Joe said check the bearing...Also it looks like that is a small dent in the housing where the turn signal lever goes through.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD |
01-17-2009, 01:56 PM | #4 |
Just here to tinker
Is it possible the shaft itself is not sticking out all the way?
How is the quality of the steering wheel? I was thinking about buying one for my '60...
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
01-17-2009, 04:10 PM | #5 |
I only replaced the upper bearing, so the lower one (probably original) being bad or worn out makes sense that the shaft is not parallel. The steering wheel seems to rotate fine, so I'm going to live with it for now and just let the paint scrape off.
Regarding the quality of the wheel...I purchased it form Classic Industries and am impressed, considering half the re-manufactured stuff you purchase is crap. I matched it up to my cracked original one and the cast looks dead on. Thanks Guys!
TimC63 Last edited by TimC63; 01-17-2009 at 04:11 PM. |
01-17-2009, 07:54 PM | #6 |
Enjoy your truck
It's been a while, but I recall an adjustment screw on the bottom of the steering column where the mast cover enters the turn signal housing.
By loosening the screw and moving it in the angled slot, you can move the bearing up or down the steering shaft. Am I recalling that correctly? Greg.
1 Corinthians 10:13 1963 Chevrolet 1/2 ton 2010 Camaro SS/RS 2014 Jeep Grand Cherokee 2016 Jeep Cherokee |
01-17-2009, 08:12 PM | #7 | ||
fixed it Quote:
CHEVY ONLY Last edited by joe231; 01-17-2009 at 08:13 PM. |
01-17-2009, 09:06 PM | #8 |
Enjoy your truck
Here is a picture of what I am talking about;
Loosen the screw, slide it either left or right, and you will move the upper bearing in or out. Greg.
01-18-2009, 02:32 AM | #9 |
Thanks Greg!
CHEVY ONLY |
