Old 01-17-2009, 02:47 AM   #1
heavychevy79
Cheyenne Super
heavychevy79's Avatar
Tube (drop) control arm Pros and Cons?
I was wondering why more people don't use those lower tubular control arms/a-frames?
I think most of them are rated for a 3" drop, and those are what I'm
interested in, so I would like some input as far as if they drag on bumps, or
do they not work good with drop springs, or if they fit with 15" wheels?
Thanks guys!
heavychevy79 is offline   Reply With Quote
Old 01-17-2009, 03:52 AM   #2
cochino12
It followed me home?
cochino12's Avatar
Re: Tube (drop) control arm Pros and Cons?
Thanks guys!
I think they cost more than spindles do , and when I used them with a 3" drop coil their was was almost no ground clearance.
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 01-17-2009, 03:58 AM   #3
Ds86C10
2WD 4 Life
Ds86C10's Avatar
more likely to hit the ground and i dont think you can run 15 inch wheels... to me there is more cost effective ways of dropping the front of the truck
Big D
1969 c10
1960 cadillac
1978 king cobra
Ds86C10 is offline   Reply With Quote
Old 01-17-2009, 04:50 AM   #4
AceX
>130dB Moderator
AceX's Avatar
Control arms will also change the suspension geometry. Spindles won't.
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 01-17-2009, 05:49 AM   #5
dooce
When the suspenion geometry is changed, what needs to be done to correct the problem? Or is it permanent?
1976 Chevy 1/2T 2wd SWB
327/Saginaw 4spd 3.73:1
LQ4 6.0/T56 Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=772071
LFSalleeII@gmail.com
dooce is offline   Reply With Quote
Old 01-17-2009, 08:03 AM   #6
Cherub
Cherub's Avatar
More than likely its the camber that is thrown out of spec. Usually an adjustable balljoint will fix it. But good luck finding someone that will adjust it.
Cherub is offline   Reply With Quote
Old 01-17-2009, 10:05 AM   #7
Wild83C10
Wild83C10's Avatar
Ihave the tubular LCA and UCA with about a 2" drop from the stock spring. I have scrapped like once or twice in the 2+ years I've had them installed. Yes the alignment will be off and you may have to install longer studs for the uppers.
However, I think they improve the handling a bit since they somewhat improve the geometry. It levels the LCA and gives you a better ball joint angle.
I can't remember if I had my 15" rims installed with the DJM LCAs or not, but I can't think of why they wouldn't fit.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 01-17-2009, 03:31 PM   #8
454HO
I have them on my truck with 15" wheels, no problem. They are a bit more expensive than spindles, but if you need to rebuild the stockers with new ball joints and bushings then it may be a wash. And yes, they do screw up the camber, but no more than lowering springs would. Definitely will need some extra shims on the upper control arm bolts.
- Greg
454HO is offline   Reply With Quote
Old 01-18-2009, 04:11 AM   #9
heavychevy79
Cheyenne Super
Cool, thanks for the feedback.
Can you use them with drop springs, or will it be too far out of adjustment?
Old 01-18-2009, 04:28 PM   #10
Wild83C10
Wild83C10's Avatar
You can use them with drop springs as I did. However you will need to relocate the shocks and you will need some blocks with shims to get the alignment correct.
turbo=
Old 01-18-2009, 07:34 PM   #11
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
They suck.
They scrape on the ground, rub on your wheels, screw up alignment, cost more, and they limited my turn radius when I ran them. Also if you are going to get them make sure to order the ones that reuse the factory shafts. The bolts on them will STRIP if you ever try to take them apart.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 01-27-2009, 02:12 AM   #12
heavychevy79
Cheyenne Super
Has anyone modded their stock control arms?
I mean if I was dead broke and couldn't afford spindles or anything, what
could I do to get the front low again?
Old 01-27-2009, 09:38 AM   #13
454HO
I've seen lots of threads on here with modified stockers to add a cup for air bags. Never seen anyone go through that much trouble just to lower the spring pocket. They usually just whack a couple coils off the spring instead.
- Greg
