Old 01-17-2009, 08:50 AM   #1
jbgroby
jbgroby's Avatar
Fuel Sending Unit Info.
Hi Group,
As most of us have figured out by now, if we changed the OEM stock gauges in our trucks to newer ones, we have issues with the new fuel sending units because of the differance in OHM's load. Sean over at E-Z wiring use to do the conversions for his customers but they no longer do this because of a liability issue (I think).
However they made a simple to follow instruction sheet on how to do the conversion yourself. All it is is changing the resistor on the sending unit.
Site Administrator, you may want to add this to your tech. article page. IF any of the members want this information, email me and I send it back to you. Make sure you put SENDING UNIT INFO is the subject line so I won't dump it as junk mail. jbgroby@charter.net
OR if anyone know how to post this to the group, I can forward it to them and we can post this on the page.
See Ya,
Jake Groby
Lacombe, LA.
jbgroby is offline   Reply With Quote
Old 01-17-2009, 09:15 AM   #2
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: Fuel Sending Unit Info.
email sent! This might be what I need!
Old 01-17-2009, 09:46 AM   #3
vin63
It's Better With Nitro
vin63's Avatar
Yes, if you're running the stock in-cab gas tank and aftermarket gauges that are a 0-90 ohm operation, then you will have incompatibility issues. I've been offering the 90 ohm OE-style fuel sending units since the early 90s. For a recent install, you can ask 62shortstep how he likes his. Anyway, if you need one, PM me and I can build and ship one to you pretty quickly. Below is a link to my thread I posted awhile back:
http://67-72chevytrucks.com/vboard/s...d.php?t=288717
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 01-17-2009, 10:26 AM   #4
62 short step
62 short step's Avatar
Works great Vince!
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 01-17-2009, 10:51 AM   #5
ol Curt
Junior Member
ol Curt's Avatar
I sent an email as well.
ol Curt is offline   Reply With Quote
Old 01-17-2009, 11:11 AM   #6
jonzcustomshop
1961 crewcab
mine is a compatibility issue, 1984 GM gas tank/send.unit, and my stock 61 guage....
Old 01-17-2009, 01:14 PM   #7
slepysal
slepysal's Avatar
email sent too
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 01-17-2009, 03:20 PM   #8
jbgroby
jbgroby's Avatar
Hi Vin63,
i did not mean to step on any toes, i contacted Sean and found out yesterday he no longer made the switch and he sent me the info. So since i have sending already newq after market, what would you charge to do the switch?
Jake
Old 01-17-2009, 03:34 PM   #9
jbgroby
jbgroby's Avatar
Here is the infor I got, hope it comes out.
Old 01-17-2009, 03:45 PM   #10
gmcpkup
gmcpkup's Avatar
I'm having trouble with a aftermarket sending unit and stock gauge. Any Ideas
gmcpkup is offline   Reply With Quote
Old 01-17-2009, 04:04 PM   #11
wild one
Registered.........
wild one's Avatar
I'm in the same boat, 1978 blazer tank/sending unit in my 66 chevy panel with the factory gauge. Any idea as to where I could obtain a 0-30 ohm sending unit as shown in the 2nd photo in the 9th post?
1966 C10 panel-400 small block/TH 350 combo
Nothing is fool proof to a talented fool!
Popcorn:
Pops at exactly 444 degreese
Expands to 44 times it's original size
Has a 4 year shelf life
wild one is offline   Reply With Quote
Old 01-17-2009, 08:42 PM   #12
vin63
vin63's Avatar
Originally Posted by jbgroby View Post
Hi Vin63,
Jake
No worries...I just wanted to make sure that the people who do not feel like messing with the sending unit have a resource who has been doing it for some time. I started modifying the OE sending units a long time ago because I was getting a lot of requests first from friends then friends of friends who had V8 era trucks for a plug and play fuel sending unit solution. I only use new sending units because I've found using old units makes for inconsistent signals and there are always variables with the float function from manufacturer to manufacturer. Building new sending units, I can ensure consistency, and once installed, it shouldn't need to be replaced or adjusted for the life of the tank. Anyway, that's just kind of a quickie background and my experience messing with these things for some time now.
Old 01-17-2009, 08:44 PM   #13
vin63
vin63's Avatar
Do you have a stock, in-cab gas tank, or have you relocated the tank to under the bed?
Old 01-17-2009, 09:33 PM   #14
gmcpkup
gmcpkup's Avatar
i have a tank under the bed
