What's wrong with this picture?
![]() I finally ran out of excuses to not start tearing down my Panel. I got the front clip off today, and was able to get a decent picture of the Rube Goldberg alt/power steering pump bracket set up. This is how it was when I bought it, and since it does work, I never bothered to make it right. I mean, I know this ain't right, but I'm not sure how it is supposed to be. And the P/S pump is on the correct brackets, as far as I know, but it don't quite line up with the crank and water pump. It leans out to the front some. Anymore and it would probably throw the belt: ![]() ![]() I don't evenknow if these are the correct PS pump and alternator.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
![]() Join Date: Dec 2008
Re: What's wrong with this picture?
I thought the power steering was always on bottom and alternator on top could be wrong though
"the other guy"
not on inline sixes. pritch,i couldnt tell you if its correct or not? because im looking for a set up for my 250 and iv never seen them in person. good luck
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE" ![]() |
Gone to greener pastures
![]() Join Date: May 2007
I'm not trying to hijack the thread....................
When somebody figures out what causes the problem, please let me know. The P/S on my big block did the same thing, and it's the factory set up. I got tired of flinging belts, so I just put a "suicide" knob on the steering wheel.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck Last edited by El Jay; 01-18-2009 at 01:20 AM. |
Maybe someday will come
I just put p/s on my 71 inline.I got the pump and brkts off of a 80 van (local Pull-A-Part)and it was kinda tweaked like yours-the pump turned out to be bad so i got another from a 81 pickup and used the same bracket at the manifold as yours but used the pump brkt from the 81 and it was perfectly in line with each other.I'll see if I can get a pic to load tomorow,not wanting to upload tonight
David ![]() 1971 C10 Soon to be DD 1988 27' Class C Tioga MH 2001 Fat Boy 2003 Gmc Envoy-Wifes ride 1992 Ford Ranger-DD for now |
#6 | |
![]() Join Date: Aug 2004
Interesting, my factory BBC pump has a similar misalignment. I spaced the bracket out from the block with some flat washers and it's held on so far. Maybe that (mis)alignment is how some of these were made...
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
Before this, I couldn't imagine a P/S pump bracket bending. But my truck ran about 35 years without a problem, then it started kicking belts off.
Then I saw that misalignment & it was like WTF?????????? A friend of mine had the same problem with his '69, with a 350. I'd just like to find out what the cause is before I start replacing parts. Once again, I'm not trying to hijack; just hoping to find a solution to what seems to be our common problem
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
Old member
[2nd picture]
Try mounting the bracket from the alternator to the pump on the back side of the alternator instead of the front side. This may have the pump kicked out or try removing the spacer that is between the bracket and the pump and find a smaller one.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
![]() Join Date: Dec 1999
Years ago we found a p/s set up from a six cyl. car in a pick a part. I'm thinking we used pics from the assembly manual or one of the original service manuals to figure the mounting out and with the spacers the correct size and location it did track straight on the pulleys. But this was over 10 yrs. ago and I'm not positive which or if a combination of the two was used. They weren't real clear so it did take a little head scratching.
Smitty '71 Short Fleetside Spring Valley, Ca. |
#11 | |
![]() Join Date: Oct 2007
I noticed the pulley out of line right off in this picture too. |
Old member
Hope this helps. I found this in the Chevy service manual series 10-30 1971.
Top left is showing power steering pump with alternator under it. You can do a save as on your computer and then blow it up to see it better. Hope it helps figure it out. If you look at your 1st picture the bracket that goes to the P/S pump is bolted to the alternator bracket itself. This isn't how the factory shows it. It's bolted through the alternator bolt hole first and the bracket has a bend in it also where yours is straight. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 01-18-2009 at 02:17 PM. |
