01-18-2009, 01:13 AM | #1 |
Lots Of NIB Parts For Sale
Im trying to go racing this year with my '69 and need some money for parts for a it. So Im selling some parts Ive collected for my '71. All parts are new in the box. Prices do not include shipping. Ask for pics.
1. 67-72 Painless 18 circuit wiring harness. P/N 10206 Sold 2. Chrome oil pan for SBC. $30 3. Aluminuim roller rockers for SBC with 3/8 stud 1.6 ratio with poly locks Sold 4. Four American Racing 17x8 polished 200S wheels. 5x5" bolt parttern with chrome lug nuts, valve stems, and center caps. Would perfer not to ship, but might be able to. $850 5. ARP rod bolts for SBC. P/N 134-6003. Sold 6. Energy Suspension greasable poly sway bar bushings. P/N 3.5175G. Sold 7. Chrome dome light, lense, and bulb. Sold 8. Cab and core support mount kit with bolts. Sold 9. 71-72 front brake hoses. Sold 10. Edelbrock performer chrome fuel line and filter. P/N 8134. $40 11. Comp Cams pushrod guide plates for SBC w/3/8 pushrod. P/N 4810-8 Sold 12. Comp Cams Magnum series 5/16 pushrods. 7.750" length. P/N 7644-16 $90 Will consider trades for c-clip eliminators, full spool, and strange or moser axles for a 12 bolt truck rear end. Thanks. Chris.
its a work in progess. 71 c-10 lwb, in the middle of frame off restoration. 69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump. 7.807 @ 88.37mph 1.60 60FT 80 g-20 van, tow rig, cammed 305, th350, 10 bolt 88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's Last edited by 71chevytruckguy; 01-17-2010 at 10:05 PM. |
01-18-2009, 01:32 AM | #2 |
Re: Lots Of NIB Parts For Sale
if shippings not to bad. ill take the dome light repop i asume.shipping would be to 97060 . is the mount kit for 71 2wd? if so interested in that pending shipping...thanks
01-18-2009, 01:36 AM | #3 |
Driven a 72
Got any pics. We like those.
1996 GMC JIMMY 1972 CHEVY C10 LWB My 72 c/10 Build: http://67-72chevytrucks.com/vboard/s...d.php?t=318729 |
01-18-2009, 01:54 AM | #4 |
you got a PN for the pushrods?
interested in sway bar bushings, rod bolts, and 3/8 guide plates. shipped to 57103.
Andy... '70 C/10 Under Construction http://67-72chevytrucks.com/vboard/s...d.php?t=298553 '71 K/20 Frame-off resto, SOLD!!! http://67-72chevytrucks.com/vboard/c...ct=2399&cat=12 '05 Silverado Z-71, CC SB, Daily Driver |
01-18-2009, 02:12 AM | #5 |
FOREVER71 - The mounts will fit a 71 2wd. Shipping for the dome light and mounts will be $12 via USPS for a total of $82
Grapdawg - What do you want pics of?
its a work in progess. 71 c-10 lwb, in the middle of frame off restoration. 69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump. 7.807 @ 88.37mph 1.60 60FT 80 g-20 van, tow rig, cammed 305, th350, 10 bolt 88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's |
01-18-2009, 02:20 AM | #6 |
finch - P/N for the pushrods is 7644-16. Shipping with or without the pushrods woud be $15. Thanks. Chris.
01-18-2009, 02:30 AM | #7 |
so $95 total without pushrods?
01-18-2009, 02:48 AM | #8 |
finch - that would be correct. PM sent. Chris.
01-18-2009, 10:11 AM | #9 |
what brand and part # do you have on the mounts ...just wanna make sure ...and is money order ok...thanks
01-18-2009, 11:48 PM | #10 |
FOREVER71 - P/N is 20463. Package says 67-72 Chevy/GMC Cab Mounting Kit 1/2 ton. Think I got it from Christian's Classic's or Classic Muscle. M.O.'s fine. Chris.
01-19-2009, 02:46 PM | #11 |
ok sounds good. one more thing could you send me a pic of the front brake hoses interested in those also if they are the corect ones....thanks
01-19-2009, 04:06 PM | #12 |
Does that wiring harness come with all the ends that you need to install?
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
01-19-2009, 05:05 PM | #13 |
FOREVER71 - Sounds good, Ill get them up tonight once I get off work.
msgross - It's comes with most of the ends for the under dash stuff, like headlight switch, gauges, steering colunm, dimmer switch, heater controls, etc. For the under the hood part it comes with just the pigtails for the headlights. Ill post pics tonight when i get off work. Thanks yall. Chris.
01-20-2009, 12:00 AM | #14 |
FOREVER71 - Here are your pics.
01-20-2009, 12:05 AM | #15 |
msgross - Pics for you
01-20-2009, 12:06 AM | #16 |
More pics for msgross
01-20-2009, 12:39 AM | #17 |
pm sent
01-20-2009, 11:12 AM | #18 |
Would you take $325 for the harness shipped to 63028
Let me know thanks
1972 K5 Build - plans - LS3-6L80e-One Tons..... 1971 CREWMAX Build.....at body shop for couple more years |
01-20-2009, 05:14 PM | #19 |
DURAMAX - Let me check with msgross since he was first inline and Ill get back to you.
msgross - You got a PM
01-20-2009, 07:23 PM | #20 |
i'll pass... I just invested in another tailgate last night...
thanks
01-20-2009, 11:15 PM | #21 |
DURAMAX - I can do that, PM sent. Thanks, Chris.
01-22-2009, 09:21 AM | #22 |
If DURAMAX doesn't take it, I will.
Thanks, Joel |
01-22-2009, 09:31 AM | #23 |
Sorry guys it took so long to get back I was out yesterday for a while. I will NOT be needing the wiring harness going a different route now
thanks anyway
01-22-2009, 07:19 PM | #24 |
What's the brand on the roller rockers?
If It'll roll I'll race it!!!
01-22-2009, 09:06 PM | #25 |
Put me in line on the harness. 325 shipped to 30157?
