Old 01-18-2009, 09:43 AM   #1
4everGMtrucks
4everGMtrucks's Avatar
73-87 rear axle info needed
i'm trying to find out if there are differences in the amount of axle splines on a73-87 1/2 ton 2wd vs 4wd????, are the housings the same?? and where will i find the i.d. numbers on the housing's to decipher the gear ratio. i've got a 4wd complete axle w/3:73's (supossedly) and am wondering if my 5 lug 2wd axles might just slip right in?
4everGMtrucks is offline   Reply With Quote
Old 01-22-2009, 09:37 PM   #2
Mike C
Mike C's Avatar
Re: 73-87 rear axle info needed
There are at least (2) different axles, the 12 bolt which has 30 spline axles and the 10 bolt that has 28. I know their are other differences as well such as brake drum width. This would effect the housing length as well.
You just need to find like and like to swap.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-23-2009, 12:25 AM   #3
skchevota
skchevota's Avatar
As stated if it is a 10 bolt, the axles will be 28 spline up till 88 then they went to 30 spline in the 4x4. The width might be differant though. I know the 88-98 have diferant widths for the 9.5" 14 bolt between the 2wd and 4x4, and they both have 6 lugs.
As for the ratio, if it dosnt have a ratio tag on it, the pull the cover and count the teeth.
skchevota is offline   Reply With Quote
Old 01-24-2009, 12:21 AM   #4
sierra4x4
sierra4x4's Avatar
If it is a 12 bolt 73-81 than yes you can swap the 6 lug shafts for the 5 lug shafts but, the shock mounts are slightly different. I have swapped a 5 lug diff into a 4wd and swapped to 6 lug shafts then cut and re-welded the shock mounts. You could just use different shocks instead of cutting and re-welding th mounts.
sierra4x4 is offline   Reply With Quote
Old 01-24-2009, 03:59 PM   #5
4everGMtrucks
thanks for the info, but where would the ratio tag be. and if i can't find it and end up pulling the cover and count the teeth on the ring gear do i also have to count the teeth on the pinion gear? and how do i do the math to figure out the ratio?
family motto: THINK! Threre must be a harder way to do it!
Old 01-24-2009, 05:32 PM   #6
LONGHAIR
It is simple division
41 divided by 10 = 4.10
41 divided by 11 = 3.73
41 divided by 12 = 3.42
40 divided by 13 = 3.08
etc.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 01-24-2009, 05:34 PM   #7
sierra4x4
sierra4x4's Avatar
If your diff is a 10 or 12 bolt their will not be a tag. Their will be an axle code stamped on the pass side axle tube facing forward a couple of inches away from the center section. If you do pull the cover off the ring gear (big one) will have the #of teeth stamped into it eg. 41:11 which is 3.73. it will also have the date and part # all in the same spot.
