Old 01-18-2009, 11:02 AM   #1
acl
acl's Avatar
Taillights come and go (no not the turnsignal)
My son's 68 has a taillight/brake light that comes and goes.The wires are fine, no breaks or bare spots, but i think he has issues with the socket. We have cleaned it and the bulb up and works for a while and off again. If you wiggle it it comes and goes as well. I have not found a place to just buy a socket and wires to splice in. Is there a socket"tightening" trick or anything else to try before replacing the whole fixture? Thanks
acl is offline   Reply With Quote
Old 01-18-2009, 11:05 AM   #2
Mayo
Cool Truck
Mayo's Avatar
Re: Taillights come and go (no not the turnsignal)
My 68 does the exact same thing
1968 Chevrolet C20 Longhorn "Cool Truck"
1937 Chevrolet Pickup - Project
Looking for a patina'd 68 50th Anniversary longbed
Mayo is offline   Reply With Quote
Old 01-18-2009, 11:35 AM   #3
Andy4639
Old member
Andy4639's Avatar
I have cut some thin sheet metal to slip over the bulb and then insert it. The socket of the fixture will let the bulb move around while driving. Cut a small peice of sheet metal and slip it inside the socket to tighten it up.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-18-2009, 11:43 AM   #4
Kayotic
Kayotic's Avatar
I suppose I could be wrong but doesn't LMCTruck have sockets for you. (thumbing through paper catalog) Maybe not. I must have seen it for the led conversion. Sorry 'bout that. Well I am looking for wiring options for my truck, If I come accross anything I will put the info here.
The other Idea about a temp fix is a good one to make sure that is the problem.
I know I have an issue with my stering column - These trucks are electricaly picky. - Good Luck
Kayotic is offline   Reply With Quote
Old 01-18-2009, 12:12 PM   #5
cdowns
cdowns's Avatar
check where the taillight bucket mounts to the bed to assure a good ground// also running a ground strap for the bed to the frame helps for proper operation of the rear lights
Old 01-18-2009, 01:02 PM   #6
tim21391
tim21391's Avatar
make sure you got two bolts in the tail light assembly... i only had one in my driver side and it didnt ground right and it made all my lights go whacko
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 01-18-2009, 02:07 PM   #7
acl
acl's Avatar
Down between the bulb and sidewall of the socket? Or the bulb and the base of the socket? both??
Old 01-18-2009, 02:44 PM   #8
Andy4639
Old member
Andy4639's Avatar
Down the sides of the bulb so there is no movement of the bulb when you hit bumps. It doesn't take a lot just enough to wedge in so it sit's good and tight.
Old 01-18-2009, 02:56 PM   #9
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Lisle (get them at NAPA) makes a tool (a brush) that fits down into the sockets of these trucks (okay, any bayonet-style bulb) that cleans (corrosion) the socket and the contactors in the socket. When you push the bulb down into the socket, you should encounter some resistance, like a spring-loaded effect. I'm sure you already knew that. I have replaced the contactor in some trailer light assy's, but not in one of these trucks.
At 37+ years of age, I'd do everything possible to re-condition these factory assy's before replacing them, but if that what it took, it would be done.
Member Nr. 2770
Old 01-18-2009, 02:58 PM   #10
sick69
sick69's Avatar
I would pull the assembly out and clean the whole thing up really well,,,,backside of the socket, back of the housing,inside of the bed, the plug portion os the socket, everything! Make sure you use dielectric grease between the housing and the bed and make sure the screws holding the housing to the bed are good and tight, make sure the lamp fits snug in the socket,blah blah you get the idea,,
If that doesn't work,,,,,,just replace the assembly. Most if not all the board venders should have them,, probably in stock.
Frank
70 chevy lwb c10
454/th400 and a 9" rearend
suicide doors, marker light fuel fill, 4" cowl , mini tub
sick69 is offline   Reply With Quote
Old 01-18-2009, 05:00 PM   #11
Andy4639
Old member
Andy4639's Avatar
If my memory is good these come apart from the wiring. Take the housing out and there should be a black rubber boot over the end of the wiring that it connects to the housing. This is cliped on to the housing with plastic clips made to the wiring harness. Clean everything up and reinstall.
