Doing it right.
Has anyone installed after market power windows in their truck? Same question for power door locks.
71 C-10 shortbed with a 68 frontend. Dechromed and painted Ferrari red. PW, PDL, PDB and factory air. 350 -10:1 pistons, ceramic hooker headers, edelbrock carb, 70r4 with a 1 pc. driveshaft. Daily driver. |
Old member
I have power windows, but no locks. I'm on my second set of motors for the windows. I just put the passenger side in a month are so ago, been on 7/12 on night shift so I'm waiting to do the drivers side. It stil is working right now also, no hurry on it.
The 1st set has been in it now for about 10 years, they were ok but the new ones have gm motors, I like them better, but lot more money. $399.00 2-motors,2-regulators,wiring, and door switches ------------------ Andy 71's Are for ever!!! or 67,68,69,70,72 71,factory tach,tilt for straight drive,gauges,ac,speed warning,clock,305 HO TPI with 700-R4, lowered 2" & 3" ,and 17" Chrome Stealth wheels, Pioneer reciever,100 watt amp, 6 disc changer, 2-10" subs (behind seat) 2-6x9 in doors, 2-3ways mounted under seat, and 2 tweaters on door panels www.geocities.com/chevy71tpi/main.html www.picturetrail.com/Andy4639
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
GYRO GEARLOOSE
The power window motors that are in most newer GM cars, the ones that push and pull a nylon belt in a track, work swell for our windows. Use your old regulator, grind off the crank gear, use the belt to push and pull the window. Cheap, easy.
------------------ Everett, Washington 57 3/4 rat, 235, 3spd 66 C-10 Panel, SWB. 350 from '68, 200R4 tranny, 3.07 rear ratio, restoring 68 C10 LWB 350 4spd, 4.56 rear dump runner 82 Camaro, 305, THM-200-R4 84 Monte Carlo 305 TH350, land tuna 85 Tercel SW, snow runner
Nevada City, CA Everett, Washington 57 3/4 rat, 235, 3spd 66 C-10 Panel, SWB. 350 from '68, 200R4 tranny, 3.07 rear ratio, restoring 68 C10 LWB 350 4spd, 4.56 rear dump runner 82 Camaro, 305, THM-200-R4 84 Monte Carlo 305 TH350, land tuna 85 Tercel SW, snow runner DISGRACED OUTLAW MEMBER OF THE DRUM BRAKE CLUB |
I found this site check it out on installing electric windows. Has a step by step conversion this might be of use to some folks wanting to try it...
http://www.a1electric.com/chevypickup1.htm
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
Well this is a step by step for a universal door lock install kit. Not really for our trucks but might be some help...
http://www.a1electric.com/door_locks.htm
CCRider
I have power locks on mine. I love them, no more haveing to lock the door with the key. I bought them localaly and don't remember the brand but the part that locks the door looks just like the ones that LMC sells. They disable the starter when you lock the doors for theft prevention. I had to install them a little different than the instructions said, but no problems in two years.
------------------ 72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
