wiper arms
Can someone please tell me how the wiper arms are taken off these pickups? I'm sure there's a trick to it but I sure don't know it.
Thanks in advance, Dan ![]()
Dan Smith Colorado Springs, CO 71 GMC Custom Camper "Longhorn" 454, TH400 73 Chevy Camper Special (Yes, it's badged a camper special) Flat Bed Motorhome conversion 454, standard tranny "DON'T TREAD ON ME !!!" My Project: http://www.picturetrail.com/sfx/album/view/20829244 , http://www.picturetrail.com/sfx/album/view/24654442 |
Re: wiper arms
thats funny i have the same problem
Heavy Chevy |
Old member
Re: wiper arms
Depends on the wiper. Some have the little clip you slide that is on the side of the arm. The ones on my 71 I use the wiper tool and it pops off easyly enough. A screw driver will also work but may tear up the paint.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: wiper arms
I have a 71, do you have a pic of the wiper tool?
Old member
Re: wiper arms
As a matter of fact I do now. I just went and clicked these for you. I bought it off the table in a NAPA store.
Here it is on the wiper arm. Just pry it back and forth and it pulls it off.
Re: wiper arms
Very much appreciated, friend. I think I can fab something that will work.
Dan ![]()
Re: wiper arms
Arrgh, still can't see what needs to be done to remove these. I can't see a clip other than the small curled piece on the inside edge. I can't see where you would use the tool to release the arm.
I can't take a pic right now as the sun is shining right in the camera lens, so I'll wait until it goes down a little more. I feel stupid this should be an easy procedure!! Dan ![]()
Old member
Re: wiper arms
If you have the 71 wiper's I don't think you have the clip on the side like I talked about. If you do then a screw driver straight down inside it and then turn it out to open the clip up from the arm.
If it's not got the clip then you just have to pry it off, thats what the tool is for. As I said before the screw driver will work but it get's the paint everytime.
Re: wiper arms
I just use a claw hammer with a rag on the cowel panel. Look for a little tab that needs to be pushed in/out. They can be hard to come off. Put one claw right on that tab or use a screwdriver to depress it. Still use the rocking motion though.
Grab a step stool or something safe to stand on for a better view. Once you have it figured out you'll be glad you did cause putting them back so they both line up is a daunting task. Such fine tooth incraments. On my '86 took 2 day's to get them off. Then when reinstalling them I must have removed and replaced atleast 10 times. You'll get it, they don't always want to come off. Mine didn't anyway. Last edited by Kayotic; 01-18-2009 at 07:20 PM. |
Re: wiper arms
Ok got them off, thanks for your help.
Dan ![]()
Old member
Re: wiper arms
Well... What did you end up doing?
Re: wiper arms
Here is a pic of the underside of the wiper arm. The little clip I am pointing to needs to be depressed in the direction the pencil is pointing to allow the arm to come off of the wiper stem. It is a little tricky to depress the clip, rock the arm back and forth slightly, and lift, all while not letting the arm spring tension work against you.
#13 |
Re: wiper arms
Oh, I see while I was out taking pics you got them off. Well Johnnyreb, hopefully this will help you.
#14 |
Old Skool Club
![]() Join Date: Jun 2001
Re: wiper arms
In my opinion, there is a tool that is much easier to use. We've discussed it before and NAPA stores sell it. It lifts the base of the arm off of the shaft in less time than I have spent on the first seven words in this reply. No wriggling. No rocking the arm back and forth. No scratching the paint on the cowl. No picture, either.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
#15 |
Re: wiper arms
I used a screwdriver and depressed the small clip you referred to while prying upwards with a wood chisel. Worked like a charm. Thanks for all the help guys.
