Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-18-2009, 09:07 PM   #1
ProStreet71
How much HP to run low 7's
Hello to all.... new to the forum. Great site by the way!
I have a 71 swb prostreet truck with a 406. I'm guessing my truck weighs in the neighbor hood of 3900 lbs. How much HP would it take to run 7.0's in the 1/8?
ProStreet71 is offline   Reply With Quote
Old 01-18-2009, 11:20 PM   #2
ton*loc
ton*loc's Avatar
Re: How much HP to run low 7's
7's flat takes 591.95hp
1986 chevy c10 in the "build" process as we speak 358 flat tops, vortec heads, .500 lift cam, NOS power shot plate system, yada yada yada
MMA PIX http://www.clgpix.com/MMA/Fighters/F...C/CoteTony.htm
MMA RECORD 24-5
ton*loc is offline   Reply With Quote
Old 01-19-2009, 12:07 AM   #3
ProStreet71
Thanks tonloc. Looks like i better go ahead and up grade my heads. Maybe the AFR 210's will get me a little closer. I will be happy if i can get this thing down in the low 7's. I have a 406 with Scat rotating assembly, 11.4:1 comp., Motown 220 heads, Comp XE292 solid roller, Team G 2" raised plenum intake, QuickFuel 850, 1 3/4 headers.
Here is a pic with a Dominator that i had for it but changed for streetability
Old 01-19-2009, 01:08 PM   #4
djracer
djracer's Avatar
if you still have the intake in the picture you will need a wilson adapter plate to a 4150 with the nitrous bars to run 7.00.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 01-19-2009, 02:22 PM   #5
Super73
Super73's Avatar
Check out the engine analyzer thread and put all your motor/truck info in. It's pretty darned close..
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 01-19-2009, 08:13 PM   #6
ProStreet71
Thanks Super73.... I will get those specs to you asap. I dont think i am to awful far from my goals. I know my current heads are holding me back a bit. There is a 79 truck at our local track in full trim, stock suspension with cal-tracks. this truck had everything it came with from the factory except A/C and runs 7.02 consistantly on a 10" tire all motor with a 406. This is the truck that started it all for me. He just put a 434 in it but hasnt got the bugs worked out yet. Cant wait to see what that truck will do this spring when the track opens up. Thanks to all that posted!
Old 01-21-2009, 01:35 PM   #7
383 Stroker
383 Stroker's Avatar
It takes a 383 with a 200shot of nitrous for my truck to run low 7's. That's real world results. But anything is possible on the internet...
Video's of my Truck Racing
1967 C-10, 383ci Sbc, TH350, 3200 stall, 3.73 gear
383 Stroker is offline   Reply With Quote
