Old 01-18-2009, 09:31 PM   #1
NYC-10
screamin eagle
NYC-10's Avatar
duct insulation for truck ?
what do you guys think about this stuff?If has glue on 1 side and it's kinda like dynamat but lighter.found it at home depot $18 a roll
SCREAMIN EAGLE
NYC-10 is offline   Reply With Quote
Old 01-18-2009, 09:43 PM   #2
tcb-1
Nothing to see here.....
tcb-1's Avatar
Re: duct insulation for truck ?
I don't see why it wouldn't work.
However, you may try a piece on piece of sheet metal, heat it up a bit on the backside with a heat gun or torch, and see if it stinks or if the glue gets runny.
but like I said, it should work and your not paying for the Dynamat name!
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 01-18-2009, 09:54 PM   #3
NYC-10
screamin eagle
NYC-10's Avatar
do you think the cab floor would get as hot as a heat duct?
SCREAMIN EAGLE
Old 01-18-2009, 10:02 PM   #4
tcb-1
tcb-1's Avatar
more than likely, hotter. especially if your running headers or a modded out mill.
is there a temperature rating on the packaging?
got to remember that ductwork is much thinner sheet steel and can dissapate heat faster. the floor will tend to soak heat up and store it, and in turn gets AND stays hotter for longer.
enough for the metallurgy lesson!
Doug
Old 01-19-2009, 08:50 AM   #5
I think it will get mashed down and not insulate with no loft.It will only serve to absorb and retain moisture...not good.Step away from the duct insulation.
Old 01-19-2009, 09:21 AM   #6
LockDoc
The Older Generation
LockDoc's Avatar
K: Not to rain on your parade so early in the morning but just about anything you put in there will retain moisture if it gets wet and isn't vac'ed/dried out, including a rubber mat with a jute back or carpet, with or without a jute back. I'm not familiar with Dynamat or duct insulation but if both or either are a closed cell product I wouldn't be afraid to use them. They wouldn't absorb moisture as much as the carpet "or" jute backing.. I don't have a clue if, or how much either would mash down.
Just my 2¢ worth.
LockDoc
Leon
Old 01-19-2009, 09:26 AM   #7
Gray Ghost
Gray Ghost's Avatar
I've got it in mine. The floor never gets that hot even with headers and pipes right below. It has held up well over the last 3 months without crushing and it helps with road noise considerably. I'll be using it in the stepside as well when it's time.
No doubt that Dynamat is better for sound and insulation, but they are very proud of that product!
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 01-19-2009, 11:30 AM   #8
Myself
I also have the "Reflectix" aluminum bubble wrap on the floors of 2 vehicles. It works great for keeping out the header heat.
Myself is offline   Reply With Quote
Old 01-19-2009, 01:17 PM   #9
NYC-10
screamin eagle
NYC-10's Avatar
this frost king stuff is not bubble wrap, its 1/8 foam with foil
SCREAMIN EAGLE
Old 01-19-2009, 05:42 PM   #10
That won`t hold moisture.
