Tooloose
Over 3 1/2 years and it fired up
I finally am far enough along to test fire the engine today. Got the wiring hooked up temporarily. It popped on the first try, so I moved the dist. a little and tried again. She fired right up and ran fine. However I can't get it to start with the key, the ignition has power to the dist. The only thing I can think of now is to check the wire to the solenoid. Any ideas? Project link below.
A legend in my own mind!!! website: http://www.persmedequip.com/ '68 c10 (current project) http://67-72chevytrucks.com/vboard/s...ht=cherry+bomb '04 silverado (better halfs) '07 wildcat 27rlwb(for sale) http://67-72chevytrucks.com/vboard/c...llinois&cat=17 |
Re: Over 3 1/2 years and it fired up
350 or 383?
nice lookin motor....im assuming the motor sat for 3 1/2 years while the rest of the truck got done ![]() i think more then you could relate to that story haha i dont think ive ever seen an alternator on the pass. side of a motor before ![]()
- Jason If you can turn, Youre not going fast enough. Favorite caption: first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around.. ..back when men were men. |
Tooloose
It's a 350, most info is in my build thread link at bottom.
Tooloose
I figured it out, after searching the faq index I found the one on neutral safety switch. Bingo when I jump the terminals at the switch it works. Now I know what to fix.
