Old 01-19-2009, 08:50 AM   #1
my67chevytruck
Under Construction
my67chevytruck's Avatar
Question Need Help with rear u-joint / u joint retainers
Hello,
We installed a '72 front member , and rear axle on my son's '67 in which we are running a 350/350. The parts truck was a '72 LWB 402/400 with a 2-piece drive shaft.
I went to oreilly and got some ujoints for a 1972 c10 one piece drive shaft 350/350 . The rear ujoint is not wide enough to fill up the ujoint space in the rear. I also picked up some ujoint retainers for a ;72, which dont fit either.
My question is should i get ujoints for a '72 402/400 for the rear? and a '72 350 350 for the front. also the rear seems to have threaded holes, did a '72 402/400 use the horse shoe type ujoint retainers or a different type?
Thanks for any help or suggestions !
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 01-19-2009, 12:52 PM   #2
my67chevytruck
Under Construction
Re: Need Help with rear u-joint / u joint retainers
I'll call a driveshaft shop, i was hoping to be able to make this work without modifying the driveshaft.
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 01-19-2009, 01:15 PM   #3
Kayotic
Kayotic's Avatar
There might be availible what they call a bastard joint for your situation, If I read correctly. It's hard to visualize and cross reference in my head.
Kayotic is offline   Reply With Quote
Old 01-19-2009, 01:38 PM   #4
my67chevytruck
Under Construction
Yeah its been awhile, but i had todo something similar to my 56 apache. I think i got it at a driveshaft shop. I will call it's been years....
EDIT, I just called driveshaft king, and they state they should have a Cross-over ujoint that should work...
Thanks kayotic, I mentioned the different size ujoint to the guys at oreilly and autozone and they were in a trance...
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 01-19-2009, 01:48 PM   #5
lowriden58
lowriden58's Avatar
im pretty sure you could swap the pinion yoke off your old rear.. both were 12bolts right?
71 cheyenne lwb 300rwhp
best 1/4 time so far 12.8 @103
http://i195.photobucket.com/albums/z...en58/001-2.jpg
lowriden58 is offline   Reply With Quote
Old 01-19-2009, 02:17 PM   #6
my67chevytruck
Under Construction
They are both 12bolt rears, I pondered that, but did not know if they would interchange between the 67 and 72 though......
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 01-19-2009, 02:28 PM   #7
brad_man_72
the boat guy
brad_man_72's Avatar
orilies ujoints (precision) are junk anyways. its always funny to ask for something not originally on the vehicle and watch their faces.
we call them conversion joints you probably needed 1310 to 3R
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 01-19-2009, 02:34 PM   #8
my67chevytruck
Under Construction
Thanks Brad, I will try to get by the driveshaft shop before they close. are autozones Ujoints any better. . I use to go to NAPa, but oreilly and autozone ran em out of town....
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
