Old 01-19-2009, 10:22 AM   #1
Stock72c10
classic=of recognized value
Stock72c10's Avatar
3 on the Tree falls out of Second
I have been having an issue with my truck falling out of 2nd gear lately. It is a three speed on the column. When I put it in 2nd with the clutch in it will sometimes "fall out" before I can let the clutch out and then I have to put it into third and then back into 2nd to keep it from grinding. Once it is in gear it will stay there, but it seems like it is too loose and I have to hold it in second until the clutch is completely released so it doesn't pop out. Is there an adjustment somewhere that will tighten it up?
Stock72c10 is offline   Reply With Quote
Old 01-19-2009, 10:36 AM   #2
woodridge
woodridge's Avatar
Re: 3 on the Tree falls out of Second
Sounds like the detent spring may be weak/broke in the side cover also, you might try tightening the shift quadrant up at the base of the column. There are three 7/16 head bolts at the base of the column, loosen them then take a big pair of channel locks and rotate the collar (can't remember which way) slightly to take the slack out and retighten the three bolts.
SEMA Network- Protect our Hobby!
71 C30 in pieces, starting to come together.
Click here for A Place For Tennessee Truck Enthusiest To Meet
woodridge is offline   Reply With Quote
Old 01-19-2009, 11:17 AM   #3
Stock72c10
Stock72c10's Avatar
Thanks, I'll try that tonight.
