01-19-2009, 09:12 PM | #1 |
Steel to Wood Bed Conversion (Installation Questions)
I'm getting ready to start my steel to wood bed conversion....I got all new metal parts from Mar-K....So I'm only doing the metal for now....I'll do the actual wood after paint...Before I get started I have couple questions for anyone that might have done it before....
Is it 100% necessary to remove the bed sides in order to get the old floor out and replace the cross sills? ....I am re-using the front bed panel w/the new adapter piece that welds on....so I was hoping to be able to leave the bed sides and front assembled and then simply replace the cross sills one at a time? Thanks in advance! Dan
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288 |
01-19-2009, 09:31 PM | #2 |
member #16
Re: Steel to Wood Bed Conversion (Installation Questions)
I think so. I pulled the front panel for replacement, but its not necessary. The rear cross sill will hold it together. You will be in good shape with the front panel in. What ever you do, just keep everything level and measured for square before and during assembly.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
01-19-2009, 10:14 PM | #3 |
Well the front panel and rear sill is different for wood so why not remove it just measure corner to corner for sq it is no big deal but will save time and make it easy to paint addtionally it is always good to install wood and everything then take back apart for paint that way teaks can be done u need to weld the rear sill to the sides if u want it to look factory
01-19-2009, 10:14 PM | #4 |
So I can basically just unbolt everything except the front panel & main rear cross sill and then simply lift the entire bed assembly off the steel floor with the intermediate cross sills still still attached to the steel floor?
Dan
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288 Last edited by Rack Man; 01-19-2009 at 10:16 PM. |
01-19-2009, 10:55 PM | #5 |
Not sure what you mean about removing the bed assembly ? I think if you loosen what you said, only the bed sides will come off. I've done a couple of these all steel and steel to wood, maybe try to explain it one more time ???
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
01-19-2009, 11:06 PM | #6 | |
Sorry for the confusion.....I'm calling the bed assembly...the two bed sides, front panel and main rear cross sill....If I leave those components assembled as a unit, can I simply lift it off the unbolted bed floor.....??....obviously, I would cut the tack welds on the main rear sill! Once off...I would add the adapter flange to the front panel and get the NEW main rear sill installed....then all sides would be back connected and I can work on getting the intermediate sills installed.... Basically,I'm just trying to avoid having to remove the bed sides...The Mar-k instructions show the entire bed getting fully disassembled...I think mainly because it shows replacing the front panel...but doesn't state whether it is required to fully disassmble the bed if you are re-using your existing front panel w/their adapter flange... As far as needing the wood for assembly prior to paint ....I actually called Mar-K and asked that very question....The lady I spoke to assured me that it was not necessary.....thats why I only bought the metal parts right now......Was that bad advice on her part ?? Dan
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288 Last edited by Rack Man; 01-19-2009 at 11:28 PM. |
01-20-2009, 12:08 AM | #7 |
You can cut the tack welds on the back siil, but the steel bed floor still goes over the top of the rear sill. I guess if you cut the floor near the sill you could take it all off together, but I don't get the point ?
01-20-2009, 12:19 AM | #8 |
You are going to have to take it all apart, the rear sill on steel floor is part of the floor assembly, so in order to get everything apart the sides must come off as well as the headgate. You can then reassemble with the fixxed headgate and wood floor cross sill, shifting and measuring to return to square, you then can replace the other four sills at your leasure, but you can't just lift floor (steel) off and everything else remaining attached, however if you were going from wood to steel you could. Hope this helps.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle Last edited by 71 super; 01-20-2009 at 12:20 AM. |
01-20-2009, 12:19 AM | #9 | |
Dan
01-20-2009, 12:30 AM | #10 |
I see, I thought it was still on the truck ! No tipping problems if it was still bolted to the frame. I don't think there really are any shortcuts here.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 Last edited by Green Machine; 01-20-2009 at 01:15 PM. |
