01-20-2009, 09:05 AM | #1 |
fuel sending unit
I moved my gas tank to under the bed and with the aftermarket sending unit the stock gas gauge when empty still shows a 1/4 tank. Anyone have any info:
01-20-2009, 09:52 AM | #2 |
TexasBowhunter
Re: fuel sending unit
Does your float move in the full range of the tank?
Are they compatible with each other? (tank/sending unit)
Build in progress for son's first truck. |
01-20-2009, 10:00 AM | #3 |
I don't know if they are compatible or not I bought the truck as a basket case and the tank was with it.
01-20-2009, 12:33 PM | #4 |
Intentionally Left Blank
I had the same problem with a "Harwood" fuel cell. I bent the float rod on the sendind unit to get it where I wanted it
1965 C-10 Short Fleet 468/TKO 5-Speed 2004 2500HD Crew 496/Ally Blacked Out (SOLD!!) 1997 Formula WS6 2004 Jeep Wrangler (Sold) 2013 Jeep Wrangler (Sold) 2017 Jeep Wrangler (Blacked Out on 35's) 2011 GMC D-Max Dually Denali 3500HD (Sold) 2015 GMC D-Max Dually Denali 3500HD (Sold) 2018 GMC D-Max Dually Denali 3500HD (Sold) 2020 D-Max Dually Denali on 33x12.50's 1979 GMC Short Bed Step-Side 4x4 350/350 Low Miles |
01-20-2009, 12:38 PM | #5 |
Are you using your original gauges in the cab?
01-20-2009, 12:43 PM | #6 |
It's Better With Nitro
More than likely, the fuel level sending unit in your new tank has a 0-90 ohm operation (late model GM). Unfortunately, your stock fuel level gauge requires a 0-30 ohm signal to function properly. You'll either need to switch to an aftermarket fuel level gauge with a 0-90 ohm operation, or try and find a 0-30 ohm resistor to replace the 0-90 ohm resistor on the sending unit...the former being much easier.
01-20-2009, 12:45 PM | #7 |
Thats what I was thinkin. |
01-20-2009, 12:49 PM | #8 |
Mine were compatible, just not properly "adjusted". I do have the factory fuel gauge. I also remember tweaking the gauge needle a little also. It's a little fuzzy, since I did it about 15 years ago. I put it exactly on the empty line at the floats lowest point. That way I knew when it hit empty I was done for.
01-20-2009, 02:16 PM | #9 |
I am using the stock gauge so maybe they are not compatible thanks for the imput. If any one knows where I can get different parts for the sending unit I would appreciate the info.
01-20-2009, 02:18 PM | #10 |
Do you have a photo of your new sending unit? Particularly, the float level assembly?
01-20-2009, 02:23 PM | #11 |
When you fill up the tank, does the gauge read full, or does it move at all?
01-20-2009, 05:19 PM | #12 | |
www.bowtiebits.com www.lmctruck.com www.classicparts.com www.ecklerstrucks.com www.gspp.com www.truckandcarshop.com www.harmons.com www.oldmusclecars.com www.classicchevroletparts.com www.classicindustries.com www.bobschevytrucks.com www.brotherstrucks.com www.mar-k.com www.wheelvintiques.com www.totallystainless.com www.earlyclassic.com www.horkeyswoodandparts.com www.raybuck.com www.americanclassic.com www.yogisinc.com www.rbsauto.com www.obschevy.com www.cheyennepickup.com www.chevypickupparts.com Not all of these sites will have fuel sending units, but they are good sources for other items, as well. |
01-20-2009, 10:20 PM | #13 |
thanks for all the feed back the float system I have, is a float that slides up a tube not one that pivots like the original. Yes it does move to full when I fill it up but it stops at a 1/4 tank when it is empty. It seems as though it sit at 1/4 full a while before it is empty
01-21-2009, 10:41 AM | #14 | |
Junior Member
01-21-2009, 01:19 PM | #15 |
Generally, it's not difficult to change. The difficult aspect is finding a 0-30 ohm resister that is the same shape and dimension. In my experience, often the type of resistor that is used for some of the fuel cell, or custom tank applications only is available in the 0-90 ohm range. There are components that you can splice into the wire harness, but I've never been able to get those to work very well.
04-23-2009, 10:19 PM | #16 |
Junk Junkie
Can anyone post up what the ohm ranges are from the factory between the different year models?
Mike 71 Chevrolet C-10 Short Bed Stepside 81 GMC 1500 Sierra Classic Long Bed |
