01-20-2009, 12:57 PM | #1 |
help with brake linkage needed
I just got done doing a 73+ front end swap on my 69 gmc. I used the power booster and master from the 73+ truck also. I have it all hooked up and working but the boster linkage is too short to reach the stock pedel hole in its full rebound position. Right now Im running a spacer in between the threaded portion of the shaft and the female end that threads onto it. It helps a little but still isnt right and I dont feel very safe with it like that.
So my question is what is the safe fix for this. I would imagine that a longer inner threaded female end is the answer, but off of what? Please any help with this is appreciated. thanks.
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=456220 Best 1/4 mile time 12.1 @ 111 w/traction issues 1969 GMC SWB 1964 chevy II Nova ht Last edited by tranz am; 01-20-2009 at 01:10 PM. |
01-20-2009, 05:50 PM | #2 |
Re: help with brake linkage needed
Is it a 3/4 ton? There's a write up in the FAQ. You get a threaded coupler and it gives you some extra length. I tried this on my 3/4 ton and couldn't get to work right. I lucked out and found a complete setup at the junk yard off a 72.
01-20-2009, 07:18 PM | #3 |
no its only a half ton. Ill have to read up on that. thanks.
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=456220 Best 1/4 mile time 12.1 @ 111 w/traction issues 1969 GMC SWB 1964 chevy II Nova ht |
01-21-2009, 01:47 PM | #4 |
Ok found that faq. thanks for that info good to know. Im really looking to find a shaft that is longer thou. maybe out of something els I dont know. there has to be a vehicle out there that used a longer one. I guess Ill just have to dig around at the junk yard some more.
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=456220 Best 1/4 mile time 12.1 @ 111 w/traction issues 1969 GMC SWB 1964 chevy II Nova ht Last edited by tranz am; 01-21-2009 at 02:08 PM. |
