01-20-2009, 01:50 PM | #1 |
Single Wall Top vs Double?
This might sound like a dumb question, but follow with me....
I have the top on my Jimmy, it is what I believe to be a single wall top? -it has interior lights -mounting points are visable from inside the truck -take about three guys to lift and move Now I have another top which I think is a double wall.... -the mounts for the bed sides are inside the top -no interior lights now here is where I am confused.....the second top is lighter then the one I thought was a single wall??? I could easily pick it up with me and one other person..... Do I have the tops mixed up or what? If not I thought the single walls were more desirable because they were lighter? Last edited by Jimma; 01-20-2009 at 04:26 PM. |
01-20-2009, 01:58 PM | #2 |
Re: Single Wall Top vs Double?
you are correct. Single walls bolt down thought the top and screw into the bedrails. Doublewalls screw from the bottom through the bedrail into the top. Single walls are harder to find because there were few made and people like them because of the light.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
01-21-2009, 10:19 AM | #3 |
Did you get her road worthy enough to go to the Silver Lake sand dunes this summer?? Chevyman63 and I have talked about trying to arrange a meeting there, for us north/northeast members...
01-21-2009, 10:27 AM | #4 |
BLAZER THIRTY!!
mine is single wall bolts down through the top mine is pretty heavy it takes me and 3 others to lift off and not do any damage i dont know the differance in weight between the two but i like the fact that i do not have to take my side panels off to remove the top and has two lights . later
49 chevy 5 window 20 year project (sold)😟 57 ford fairlane (dad's car never got to it before he passed away R.I.P I LOVE YOU DAD.) 62 GMC 305 V6 custom L/B 72 HIGHLANDER K5 BLAZER 2nd owner 71 K5 MAMMA'S RIDE! 63 GMC 4X4 305 V6 62 GMC SHORT BED SERVICE BODY V6 (STUMPY) 74 GMC CUSTOM 1500 L/B |
01-21-2009, 09:49 PM | #5 | |
I am glad that I had the tops right. I was really confused because I have heard from a lot of people that the single wall is more desired because it is lighter and that was definitely not the case. I would say that the double wall was a good 75 pounds lighter then the single? Thanks for your response! |
01-22-2009, 12:00 AM | #6 |
The only advantages to the single wall:
Overhead lights Can remove top without removing the side panels on CST equipped trucks. With that said, I still prefer the double wall.
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels Last edited by 1970cstblazer; 01-22-2009 at 12:00 AM. |
01-22-2009, 06:38 AM | #7 |
Have yet to see any 'real' weight numbers between the two for a comparison to prove either-way which one is heavier.
I've pulled off double walled tops that felt light-ish and others that were miserable to lift off. Wonder if the weights of the double walled tops varied any over the production years...? |
01-22-2009, 10:37 AM | #8 |
I prefer the single wall for the inside roof design. It just looks better without the line down the middle, and the single walls also seem to have less of a problem with the roof sagging in the middle. The lights are a bonus.
