12-08-2002, 08:29 AM | #1 |
Gasoline quality
Edelbrock 1904 wasn't cheap. Are there any add to the tank type fuel system cleaners that ya'll recommend? Any other maintenance tips other than disassemble and clean?
350 Crate 10 bolt 3.73 2.5 lift 32x11.50 1904 Edelbrock http://www.oplnk.net/~spirit/K5front.jpg |
12-10-2002, 12:48 PM | #2 |
I dont understand. Are you looking for something you can pour into your gas tank to help keep your system clean? If so I dont know I dont use them.
What you should do is add an inline filter to your new carb. I dont like the filter on the Q-Jets so I put on before it. So its double filtered which you really dont need but atleast you can remove/replace/clean the inline filter and not have to touch the one in the carb. Im scared that Ill strip the threads or break something on the front of that carb. I have never had good luck with them. When I ordered my 1904 Edelbrock Q-Jet from Jegs the filter inlet was stripped and leaked everywhere when I started it. They reaplced it for free, but thats one more reason Im not touching that filter. When I give my truck a tune up (oil, plugs, check timing etc.) I spray some carb cleaner on & in the carb. Mike also has a 1904 and keeps his sh*t souppa clean. Maybe he will have some good tips for you. You better check his site first though, or he will get really mad. j/k
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * |
