Old member
Head Lights
Just thinking outloud.
Do you point the head lights straight out or do they crisscross each other? What is the proper way to do it. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: Head Lights
The best way is to take them to a shop and have them aimed. They have a device that suctions on the headlight and level bubbles. Or you can pull up to a wall and aim them strait ahead and a liitle in and down.
its all about the +6 inches
Re: Head Lights
down and to the right
![]() Join Date: Jul 2004
Re: Head Lights
Good foggy night and straight gravel road with no traffic works for me ! We usually make them slightly crosseyed. You want the lights to converge on the road together about where they run out of light. We always adjust high beams and hope the low beams are OK. On high beam, if you would drive down the center line (no traffic of course) we shoot for equal light on both sides, with the beam converging straight ahead on the line.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
Old member
Re: Head Lights
When I put the lights in it I set them how they are now. I was curouis if I had done it right. From what you all have said I should be fine.
