![]() Join Date: Nov 2008
Rear end question
I am under the impression from this forum that 5 lug axles from a 71 or 72 chevy cannot be swapped into a 70 or below housing because the lengths are different. Depending on when a '70 was made it may have the longer axles already.
Is the overall length of the rear end changed? If so, if a whole rear end is swapped is there anything different with the 71 or 72 rear end besides the fact that the rear end is a little wider? |
![]() Join Date: Jul 2005
Re: Rear end question
What you say is what I think. Some of these wizzards swap out and end up with wider housings then use a different backspacing for the wheels to compensate the length difference. One or more will chime in here. But them that have done this goter down pat.
The biggest problem people have, is other people Thou shalt be cool and not hassle ![]() Be a site supporter. ![]() The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2 Last edited by larry may; 01-20-2009 at 05:59 PM. |
Too Dumb To Know Better
A late year 70 model may have the wider rear end. My Jimmy did and the 5 lug axles were the same width. Some people put the 5 lug axles in the narrow rear ends and run them, but I wouldn't.
