Old 01-20-2009, 09:18 PM   #1
pokethesmot
profeshinaly unimployed
pokethesmot's Avatar
valve cover breathers
i have a PCV valve hose hookup on my air filter(edelbrock) and on my carb so witch one should i use as a breather for my valve covers and for a little while my left valve cover had just a regular air filter breather on it and after it would warm up smoke would come out of the breather...why is this?...it never did this on the right hand valve.
"having mud flaps is like asking for a smaller trophy"
pokethesmot is offline   Reply With Quote
Old 01-20-2009, 11:59 PM   #2
asphaltburner
asphaltburner's Avatar
Re: valve cover breathers
Yo! pokethesmot!
I like to use the hookup closest to the manifold. In fact, I set my engines up so that the PCV dumps into the manifold directly or through the base of the carb. That way the burnt oil/fuel fumes from the PCV don't go through my carb.
Smoke from the breather is the burnt oil/fuel gases escaping past the piston rings and vaporized oil from the crankcase. That's why the engine has Positive Crankcase Ventilation,...to suck those gases into the intake for burning in the cylinders. The older the vehicle, the more smoke due to increased clearances, and more escaped gases in the crankcase. Perhaps the right hand side has collected more gunk and the left is the path of least resistance.
Todd.
'78 3/4 ton 4x4 custom "Todd-built" FRANKENTRUCK!
asphaltburner is offline   Reply With Quote
Old 01-21-2009, 03:25 AM   #3
84 400
Sb 400 club
84 400's Avatar
Todd said it all. Thats the way I do mine. I run a breather on one and the pvc to the carb base on the other side. Works fine for me.
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
