Old 01-20-2009, 09:24 PM   #1
pokethesmot
profeshinaly unimployed
pokethesmot's Avatar
my speedometer gauge jumps
well i dint get a great look at it but on my way to school it would be fine and go to the right speed but as soon as i keep going that same speed it will jump up and down in what it look like 5-10 mph increments and since i don't have a license it is kind of a big issue for me to go the right speed lol but what do i need to do to fix this
"having mud flaps is like asking for a smaller trophy"
pokethesmot is offline   Reply With Quote
Old 01-20-2009, 10:14 PM   #2
asphaltburner
asphaltburner's Avatar
Re: my speedometer gauge jumps
Yo! pokethesmot!
You need a new speedo cable.
Todd.
'78 3/4 ton 4x4 custom "Todd-built" FRANKENTRUCK!
asphaltburner is offline   Reply With Quote
Old 01-20-2009, 10:20 PM   #3
Albatrossian
Georgia Boy
Albatrossian's Avatar
Need a new speedo cable.
81 GMC High Sierra, 2WD, 357ci/700R4, 3.73s, posi.
Albatrossian is offline   Reply With Quote
Old 01-20-2009, 11:30 PM   #4
79Silv4x4
Workaholic
79Silv4x4's Avatar
Ya need a license
Seriously though, I think the cable cable is the way to go. . .
1979 K-10 Silverado (work in progress)
1991 V1500 Subruban
1999 Suburban LT 4x4
2006 Suburban LTZ (daily driver)
79Silv4x4 is offline   Reply With Quote
Old 01-20-2009, 11:36 PM   #5
PhilaTruck
Right on the line, baby!
PhilaTruck's Avatar
Not that you need to hear this but get your license. Yea, I know, Duh.
If I remember correctly, you have a "less than stock" exhaust. It don't take much to get you pulled over.
Anyhow- my speedo does the same thing. And I just replaced the cable. It didn't work at all before.
83 GMC 406 th400/3.73 Eaton Truetrac posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly, but getting built right, although slowly
Click and scroll down for site vendors!
Subscribe here!
PhilaTruck is offline   Reply With Quote
Old 01-21-2009, 12:32 AM   #6
willett
Another Day, Another Dollar
willett's Avatar
mine has done it a few times while driving down the highway.
jumps up to the very top and and then down to zero and the up and down and it goes ape**** to the point that i'm going to pull over and disconnect it, and then it works fine again!
weirdness
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 01-21-2009, 03:46 AM   #7
heavychevy79
Cheyenne Super
heavychevy79's Avatar
Nope. I changed out a perfect working 85 MPH speedo to a 100 MPH speedo
that now jumps around a 20 MPH window.
My gas gauge jumps around too, and it has no cable.
I think there is a friction peice in the gauges that wears out, but how to fix it
I have no idea.
heavychevy79 is offline   Reply With Quote
Old 01-21-2009, 08:34 AM   #8
pokethesmot
how much is a speedometer cable? and about the license. the test place is kinda far away and my mom has terminal cancer so she never really feels good enough to take me and i only drive to G.E.D school my girlfriend drives almost every where else cuz she has a license lol
Old 01-21-2009, 10:45 AM   #9
mhicks
mhicks's Avatar
I have never seen the fix for this problem but it sounds to me like the flexible shaft that turns the speedometer is binding inside it's housing. It binds then torques up a little bit then lets go and that is causing the jump. Maybe pull the cable and put some good lubricant on it.
Sounds good to me?
mhicks is offline   Reply With Quote
Old 01-21-2009, 11:06 AM   #10
PhilaTruck
PhilaTruck's Avatar
That sounds like that makes sense, mhicks.
Cables are what, $25? (I paid less for mine.)
But before you buy one, definitely lube the thing. Unfasten both ends and squirt some wd40 down the cable.
I'm very sorry to hear about your mother's illness.
-Todd
Subscribe here!
Old 01-21-2009, 12:13 PM   #11
silvereagle07
silvereagle07's Avatar
My old 81 was the same way, it would bind in the sleeve. I remove the instrument cluster and sprayed CRC Powerlube into the cable housng. It worked fine after that.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 01-21-2009, 01:49 PM   #12
Malo83
Cruzzzn' Vet
Malo83's Avatar
Mine would bounce around whenever i would go on a long trip at high speeds, but just around town it never acts up
Malo83 is offline   Reply With Quote
Old 01-21-2009, 02:07 PM   #13
Pyrotechnic
Pyrotechnic's Avatar
One thing you can try first before spending money is to remove the speedometer cable from the truck, then pull out the inner cable. Soak it in solvent and get it clean. Spray some carb cleaner down the outer cable and get the gunk out of it. Let everything dry.
Get a can of white lithium grease and coat the inner cable with it, then thread it back into the outer cable. Reinstall on your truck and it should work like new.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 01-21-2009, 02:11 PM   #14
pokethesmot
i know this is gunna sound like a newb question but where does the speedometer cable connect too
Old 01-21-2009, 02:13 PM   #15
mhicks
mhicks's Avatar
Back of the transmission.
Old 01-21-2009, 03:55 PM   #16
dammitmitchell
the pollock
dammitmitchell's Avatar
hey after u pull it and reinstall it make sure it isnt hitting your exhaust pipes itll melt in in a few moments..
i had my belly dumps installed and the jerks left the cable hanging on my pipes and cost me 20 bucks and a few moments of heartache
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 01-21-2009, 05:15 PM   #17
PhilaTruck
PhilaTruck's Avatar
That's good advice. That's what the jerks did to me!
Hey wait a minute, I did it myself. Oh well. I'm a jerk.
Subscribe here!
