Eat My Rust
Recomended Zinc happy oils
I know of the whole Zinc issue, but besides Royal Purple (expensive), what else is there that's a good bang for the buck? Doing an oil change on the CST10 this weekend.
Moderator
![]() Join Date: May 2007
Re: Recomended Zinc happy oils
Amsoil...but it costs just as much.
Active Member
Just pick up a pint of GM EOS and put 1/2 the bottle in with your oil change
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles ![]() 18.5" x 31" Hoosier Pro Street Radials ![]() ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree ![]() |
diesel oils still have zinc.
1967 Shortbed "Project Patina"
I am running
On the college boy budget...
I also run Valvoline VR1 in my '68. I just go down to Napa and have them order me a case of 10w-30, still not the cheapest but I've found it to be the best route as far as price and availability.
-'68 C10 short/step- 350/350 |
its all about the +6 inches
most of the diesel oils have less zink in them than the gas oils now.
I've been using this additive or you could use their oil- http://www.motorheadoil.com/
1970 K20, 350--- SOLD 05 silverado extended cab short box- duramax Jeep wrangler unlimited |
You may want to check out zddp plus oil additive, it has very high concentration of zinc and phosphorous... I just got 3 cans but haven't used it yet. I am going to use it in the engine that I built recently but haven't fired it up yet.
more info @ http://www.zddplus.com/
72 Chevy C20 Longhorn 72 Chevy, K20 Custom Camper 67 Chevy, LWB, C20, 350/350, PS, PB, 65 Jag MKII |
big rigs are having emissions issues too, they are getting very strict on them last few years.
On gas engines, it wasn't so much for emissions, the ash produced as the zink would burn off was clogging cattilitic converters and clogging them. The auto makers have been askin the feds for 15 - 20 years to get rid of the zink |
I hate to brag,
But here in Colorado they repealed emissions on passenger cars and trucks last year because our air is so clean. With the new administration and more Dems in our local governments that may change soon, but for now we don't have to pass inspection or emission tests. Dan ![]()
Dan Smith Colorado Springs, CO 71 GMC Custom Camper "Longhorn" 454, TH400 73 Chevy Camper Special (Yes, it's badged a camper special) Flat Bed Motorhome conversion 454, standard tranny "DON'T TREAD ON ME !!!" My Project: http://www.picturetrail.com/sfx/album/view/20829244 , http://www.picturetrail.com/sfx/album/view/24654442 |
#13 |
mini truck racer
I hear lubri-plate 30W is the highest in Zinc content as it is mostly marketed as air compressor oil . VR-1 is my choice , but i have all roller cams . I agree with the GM EOS at oil changes .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
#14 |
Eat My Rust
Good thing is my dad works at a Cadi dealership and that's where I'm tidying up the truck in the underside, and oil change and inspection and such. Might get the EOS for free.
#15 |
use 4 qts of a good oil and a qt of lucas. that stuff is GREAT. we also used to run it in the rear end of our racecar and after a race you could lay your hand on the diff
-Scott- 1970 C10 shortbed 396 1969 C30 dually flatbed "Vidalia" |
