01-21-2009, 02:17 AM | #1 |
door hing question
Were can i buy door pin bushings for a 1970 gmc. my doors you can pick up on the back and wiggle. i call autozone and orielly and they only go back to 73 for them. I remember seeing a faq on here of how to rebuild them. anyone know that link?
and a part number... thanks |
01-21-2009, 02:58 AM | #2 |
Re: door hing question
Go to Advance Auto look in the "help" section. Take a tape measure.
I am sure you can find what you need. Thats what i have done in the past.
2008 Chevy HHR 1/2 panel. 1949 Chevy Panel truck(just sittin, waiting) Board member #6 |
01-21-2009, 03:25 AM | #3 |
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
01-21-2009, 08:21 AM | #4 |
You can still buy the bronze bushings at the dealer. I just bought 8 of them last week. And as stated above, they are also in the help section of auto parts stores. They also have the pin kits there.
1997 GMC Sierra Ext 1965 Mustang |
01-21-2009, 11:45 AM | #5 |
The pin kits in the help section are labelled GM only no specifics, the kit has 4 bushings and 1 pin (which will have to be cut to fit or old one reused) actual process of rebuilding takes about 10 minutes,getting old pin out may take quite a bit longer. I have had good luck soaking in Gibbs oil for 2 days and then using a 2lb hammer, punch and a strong vise. Good luck.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
01-22-2009, 01:20 AM | #6 |
Alright guys i have been to every parts store we have around here and cant find anything, does anyone have a part number and store were bought? Anyone take pics of the process while doing it, because i have soaked it with wd40 every 20 min for like 4 hours and then try to hamer out the pin from the bottom and it wond budge..... any suggestions, again pics and part numbers would be very helpful.
01-22-2009, 01:35 AM | #7 |
I had to heat mine with a propane torch to get mine out. Still had to hit them good though.If you only need one door repaired I will send you what I have left from my kit. pm me your address.
Chuck 68swb Fleetside build ''Choncho'' http://67-72chevytrucks.com/vboard/s...d.php?t=374892 My trailer redo http://67-72chevytrucks.com/vboard/s...69#post5893869 Chuy my 59 bug http://67-72chevytrucks.com/vboard/s...d.php?t=653798 Putnam 87 GMC Shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=707687 |
01-22-2009, 09:12 AM | #8 |
WD40 is only good for oiling up a bicycle chain. Get some type of rust buster. Some of these pins have to take some hard wacks with a BFH before coming loose. As stated above, you may need to heat it.
1997 GMC Sierra Ext 1965 Mustang Last edited by 70GMCer; 01-22-2009 at 09:13 AM. |
01-22-2009, 09:53 AM | #9 |
Got it . I'll get it in the mail tomorrow.
01-22-2009, 02:54 PM | #10 |
Moderator
If you whack it too much, you will just mushroom the bottom of the pin and you will never get it out.
If you want to try that method, soak them in PB blaster or liquid wrench for a few days. Then use a strong vise to hold them in place, with an old socket under the button head of the pin for more support/stability. Get a hand held sledge hammer, and whack it one time, as hard as you can. That should drive it flush with the bottom of the hinge and bust it loose. You can use a punch as Harold stated to get it the rest of the way out. In some cases, the hinge pin has become one with the hinge, and no matter how much or hard you hit it...it will never come out. In this instance, use a dremel tool with a small cutting wheel, or a 3" cutoff air tool ($6 at harbor freight) and cut the pin in between the hinges carefully. Then use a punch to remove the pieces. I have restored several sets of hinges, using both of the above methods. Good luck. |
