Front wheel/tire size for racing
What size front tires/rims do you guys use for racing,I have a 67 ,lowered 4 1/2 inches in front/ 6 in rear,need some advice, do you run a regular tire or a race front runner, thanks Brian
Re: Front wheel/tire size for racing
I run a v rated front tire only because i have 16" rims and hard to find skinnies for a 16x8 My tires are a 225/60/r16.
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 |
Would a 28x4.5 Goodyear work? Or should I go wider /shorter? Help please
if its drag only you could probably run a 25 or 26 inch. The shorter tire should help react on a pro tree.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
Machinist
Mine are 195 r 15 on 3.5 wide rims
I'm riunning a 195 on a 5" wheel. Can't remember the side wall but it's 27.5" tall.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 Last edited by Super73; 01-30-2009 at 08:26 PM. |
I am running a 195/64/15 on a 6 inch wide wheel
