Old 01-21-2009, 02:09 PM   #1
6600DURAMAX
6600DURAMAX's Avatar
Need Brackets Laser or Plasma Cut in St. Louis MO
I need a shop or well skilled person to cut some traction bar brackets out of 3/8'' plate to attach my 1'' heim joints. Have the drawings complete, basically just a big shock tab, just need to find a shop in the St. Louis area to perform.
I tried cutting them with my plasma, but 3/8'' is just a little to much for it and I needed more grinding than I am willing to do.
Any help is appriciated
thanks guys
1972 K5 - LS3/408 (595Hp) -6L80e-One Tons with 4.56, 20'' Beadlocks with 37'' rubber, full TMI interior, JL Audio .....
1971 CREWMAX Build.....at body shop for couple more years
6600DURAMAX is offline   Reply With Quote
Old 01-21-2009, 03:53 PM   #2
cdowns
cdowns's Avatar
Re: Need Brackets Laser or Plasma Cut in St. Louis MO
speedway motors has quite a few mounting brackets in their cata;ogue
me, i 've always just used my trusty old jigsaw and cut my own
Old 01-21-2009, 04:29 PM   #3
6600DURAMAX
My biggest problem is I am using a 1'' heim joint, so the bracket will need to have a 1'' hole in it, most mounting tabs only go up to 3/4'' in hole size if that. These heims are huge.
I also tried a jigsaw on some 1/8'' plate I had and I was only able to cut about an 1'' before the teeth on the blade were gone, and it was a Bosch blade. I cant even imagine trying to cut 3/8'' thick plate with one.
Old 01-21-2009, 04:46 PM   #4
mr48chev
mr48chev's Avatar
Many ag related welding and fab shops can do that sort of work. It may cost a bit more as you have what they would consider to be a small job by their standards. Otherwise there may be a rod shop in the area that can do the job.
Locally there is/was a guy who was cutting out pieces for modified Jeeps and selling them. There is also a guy In the Vancouver Wa area who sells on ebay who I believe will do custom cutting. I bought an engine/trans adapter plate from him and the work was nice even though the plate was rather light weight.
You might also check to see it there is a trade school in the area with a machine shop class.
Old 01-21-2009, 06:41 PM   #5
6600DURAMAX
I will check on ebay and some ag shops around here. I was hoping someone would know of a 4x4 offroad shop that did this kind of stuff locally and at a decent rate.
Will continue to keep digging
thanks guys
Old 01-21-2009, 06:54 PM   #6
lowriden58
lowriden58's Avatar
Contact this guy http://www.illusivefabrications.com/ he is on the RangerPowersports forums and does CNC work.
71 cheyenne lwb 300rwhp
best 1/4 time so far 12.8 @103
http://i195.photobucket.com/albums/z...en58/001-2.jpg
lowriden58 is offline   Reply With Quote
Old 01-21-2009, 07:04 PM   #7
El Jay
Gone to greener pastures
Check your local Jr. College.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 01-21-2009, 07:21 PM   #8
OhNoJoe
OhNoJoe's Avatar
In Springfield Illinois you can sign up at the Capitol Career Center for 75 bucks and then use the shop every Tuesday night for 6 weeks. Try a place like that
OhNoJoe is offline   Reply With Quote
Old 01-21-2009, 07:58 PM   #9
hilandr452
hilandr452's Avatar
Why can't you use a cutting torch for that? If you have a steady hand you can get it very close and smooth the edge with a hand grinder.
Dan
Dan Smith
Colorado Springs, CO
71 GMC Custom Camper "Longhorn" 454, TH400
73 Chevy Camper Special (Yes, it's badged a camper special) Flat Bed Motorhome conversion 454, standard tranny
"DON'T TREAD ON ME !!!"
My Project: http://www.picturetrail.com/sfx/album/view/20829244 , http://www.picturetrail.com/sfx/album/view/24654442
hilandr452 is offline   Reply With Quote
Old 01-21-2009, 10:47 PM   #10
yad
Driving the Thin Blue Line
I'm in St. Charles MO. I would call Allied Motors(It might be called Bessel Motors now). The owner, Ronnie Besselman has an awesome CNC machine in his shop on First Capitol. He can make darn near anything with that machine. And he's a nice guy.
yad is offline   Reply With Quote
